Old 05-22-2009, 08:51 PM   #1
mailman50
Default Main Gear Rubbing?
Any idea on how to get the front top of the main gear to stop barely rubbing the upper frame?
mailman50 is offline        Reply With Quote
Old 05-22-2009, 10:37 PM   #2
schoep
If you crashed with it, there is more than likely a small crack at the hub making it wopple and hit the frame.
CX2,MSR,,R/C weapons pod, Camera pod, Scale Hughes 500 W/Blade 400 mech, HK450, HK500CMT
schoep is offline        Reply With Quote
Old 05-22-2009, 10:56 PM   #3
fast400
take out the gear and inspect it for cracks, if its not cracked then you can get a thinner shim
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote
