Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Motors, ESC's, BEC's, Chargers and Batteries
Electric Motors, ESC's, BEC's, Chargers and Batteries *No Commercial Ads - E-Helis Stuff Only
Old 05-30-2009, 12:02 PM   #1
Phaedrus
Default FS: Hacker A40-10L ET 8-Pole Motor
BRAND NEW IN BOX
$100.00 Including Shipping in US
Retails for $150.00
Hacker A40-E Turbine 10L (5mm shaft diameter) 1100Kv motor (89% efficiency) 8 Pole with smooth case for 50 size helicopter and 6S lipo batteries
Max. RMP: 35,000
Max. Power : 2000W
Max Amp: 90A / 15 sec
ESC timing: 8 - 15 deg
ESC Switching Freq: 8KHz
lo (No Load A): 1.7A
Resistance: 0.019 ohm
Motor Length: 70mm x 48mm Diameter
Weight : 315 grams
FREE SHIPPING IN US.
US Shipping only.
PayPal preferred
AMA Leader Member
Team Futaba
Raptor 90SE/YS91ST - T550E FB - T550E FBL w/CGY-750
Phaedrus is offline        Reply With Quote
Old 06-02-2009, 12:07 PM   #2
butters149
Default hacker
will this 2200mah 35C 6S lipos? how much flight time will i get? can i use my trex 500 stock esc?
butters149 is offline        Reply With Quote
Old 06-04-2009, 05:37 PM   #3
Phaedrus
How long a flight you will get depends on your set up. On 6S this motor will turn at 22,440 (3.4 volts per cell loaded). I cannot tell you how long your 2200 packs will go without knowing what kind of amp load you will have.
AMA Leader Member
Team Futaba
