Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 05-30-2009, 09:58 PM   #1
cyclist01
Default dx6i basic settings for mini titan
I am in the middle of my first mini titan build and it is as follows
ds285 on the cyclic
inolab 201 hb on the tail w/ jr g500t gyro
metal servo holders
Can some one please give me the basic setup/parameters(for a beginner) for a dx6i and I will adjust from there as I know that settings will vary per each pilot's flying style
All feedback is greatly appreciated
Thanks,
Brandon
cyclist01 is offline        Reply With Quote
Old 05-31-2009, 07:46 PM   #2
JustPlaneChris
Brandon, your best bet is to watch the Finless Bob setup videos and do everything from scratch. Sharing transmitter settings rarely works, and usually ends up being more trouble than if you'd just started fresh. This post has links to all the good videos:
http://www.helifreak.com/showthread.php?t=41692
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is online now        Reply With Quote
Old 05-05-2010, 11:33 AM   #3
B335
Location: Gone. Too many assholes here and I am one less.
I'm in the same boat about to buy a DX6i, so what a pity no one bothered to put down the basic dx6i settings for the Mini Titan. All very well pointing at Bob's vids but nothing there for the Mini Titan (or indeed any of the Thunder Tiger range), and the DX6i vid for the Trex450 is not really relevant as many of the figures needed for the MT are different, due to the way the MT's swash functions.
What the OP asked for (which I was hoping to find as well) were some basic figures for the DX6i from a Mini Titan pilot, as a starting point.
Any help anyone?
(already been thru Bob's vids, so please don't suggest...)
B335 is offline        Reply With Quote
Old 05-05-2010, 12:16 PM   #4
Mikej
The problem is that it will depend on which servos you use (reversing etc.), which arms you are using on the servos, which holes on the arms, which motor, which pinion etc. etc. Someone using exactly the same set-up may have different settings due to their experience level etc..
Nic - if you have any issues you are very welcome to phone me ....
Mike.
Mikej is online now        Reply With Quote
Old 05-05-2010, 12:24 PM   #5
B335
Thanks Mike, I might take you up on that. I'm due to get mine on Tuesday, but thought I'd plan ahead and try to get some ballpark figures for the settings like the OP wanted, as I guess my cheapo Perkins TX is not gonna provide anything the DX6i will recognise and it means trying to fumble around in the dark to get some figures to start from.
Already downloaded the manual for the DX6i so I'm just going through it to see how it looks.
If I get stuck round about Tues or Wed evening you may get a call from an exasperated bb!
Nic
Old 05-07-2010, 12:17 PM   #6
nwjhawk
Not sure what it's worth, but I'll share. I have JR DS285 cyclic servos, Futaba GY520 gyro, and a S9650 servo on the tail. I setup mine for +/-10 deg of collective pitch and +/-6 deg of cyclic pitch. DX6i settings are as follows:
D/R&EXPO
Aile: 15% EXP
Elev: 15% EXP
Rudd: 75% D/R, 30% EXP
TRAVEL ADJ (DN/UP or L/R)
Thro 100/100 Aile 105/100
Elev 106/105 Rudd 100/100
Gyro 100/100 Pitc 100/100
GYRO (>50% HH, <50% Rate)
0: 70%
1: 30%
THRO CUR
Norm: 0, 45, 75, 87.5, 100
Stunt: 100, 87.5, 75, 87.5, 100
PITC CUR
Norm: 40, 45, 50, 75, 100
Stunt: 25, 37.5, 50, 75, 100
SWASH MIX
Aile: +69%
Elev: -69%
Pitch: -67%
nwjhawk is offline        Reply With Quote
Old 05-07-2010, 02:35 PM   #7
B335
Thanks nwjhawk, I've just ordered my dx6i so I'll see how they compare with the figs off my old 35mhz tx when my dx6i arrives.
Anyone happen to know if the rubber antenna on the dx6i is removable for transit in carry case or is it a one-piece permanent attachment? Manual doesn't mention it.
Old 05-07-2010, 06:00 PM   #8
Mikej
Antenna not easily removable (it's a screw-driver job and then it would be dangling on the lead - not ideal), and is more like hard plastic than rubber
