| Belt CP E-Sky Belt CP |
What size hex wrench is needed for this set screw?
Kane EXI Frame, Trex 450SE V2 head, 450HDX/3200kV, Dynam ESC, Trex flybar, Trex paddles, Trex/EXI canopies, Align 325 Pros, SG90 cyclic, Esky tail servo, Flightmax and Rhino LiPos, Tech 450 metal V/H fins, 13T Rhino pinion, CNC tail, Trex 450 tail rotors, EK2-0704B HH gyro, DX6i and AR6200. |
Is it 1.3mm?
or 1.5mm
Alex To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Stop by say hi :-) 500 ESP: Ely Q Comp: "Kasama'd Trex 600N: |
I just got a couple of Rhino pinions from HeliDirect, and I thought the hex driver I had was the right size but it wasn't...ruined one of the set screws. I'm pissed. So, I need to find out exactly what size I need so I can order the correct size. Glad I have another pinion. Don't really want to buy a whole set of metric hex drivers right now.
Should ditch the whole lot and get a motor with a 3.17mm shaft...and new pinions. This is crazy.
ok understand but a set of allen keys doesnt cost alot and it much better to have all eventuallitys covered
#6 |
I have several pinions from several sources (although none are Rhino), both 2.3 and 3.17 shaft size, and all use M3 thread set screws, which use a 1.5mm hex driver.
M3 set screws are pretty common on 450-size helis (pinions, shaft collars, tail blade hub, etc), and I have found that it's really easy to round out the hex drive. Usually OK the first, maybe second time you tighten them, but then they strip. So I bought a bag of 20 of them a while back, and now I rarely bother reusing them at all. I figured it was better to spend a few pennies on a grub screw than end up with a pinion jammed on a shaft, or not being able to change a main shaft because I couldn't get the collar off
Belt CP: stock frame, motor, ESC (with UBEC) and boom - all else upgraded! Mini Titan: kit w/ AH-1W Cobra conversion, custom painted. EXI 450: kit with various electrics. HK500-GT: w/ scale AS350 fuselage. Walkera 5G6: custom sport tail. Blade mSR |
#7 | |
I used some red loctite and it works great and the heli flies great (except for my weak battery.) Obviously, when I upgrade to another motor with a 3.17mm shaft (along with a new Rhino pinion) I'll set it up correctly.
#8 |
1.5mm and 1.6mm - Trust me on the 1.6, some of them are made a hair bigger.
If you can't get them out, give them a squirt of WD40, or heat them up for a few seconds with a solider iron. That'll loosen them up, especially if they have threadlock on them. ![]() |
