Old 06-05-2009, 12:43 PM   #1
ronkreba
Question plug ESC where?
Hi, Everybody,
I have a new Exceed transmitter/receiver FS CT6A. The receiver's plug-ins are labeled from the top; battery, channel 6, channel 5, and so on in descending order. Into which channel should I plug my ESC?
Help appreciated!
ronkreba is offline        Reply With Quote
Old 06-05-2009, 12:47 PM   #2
jrohland
Default 1
On every receiver I've seen the throttle/bat channel is 1. You really can't hurt it if you plug it into the wrong channel. MAKE SURE your motor is backed off the main gear. I say that because if you plug the ESC throttle into a channel that is up high, it could spin up at high speed.
If you have a receiver pack, plug that in and use a servo to id each channel on the receiver.
jrohland is offline        Reply With Quote
Old 06-05-2009, 12:50 PM   #3
latte
If you do not have a throttle channel, then I'd just plug the esc into the battery-port to supply the receiver, and one by one connect any servo down the numbered inputs while moving the throttlestick.
When you then have "found" the throttle-channel, you can go ahead and connect the esc to that channel.
Hope that helps!
700E DFC - Ikon
700N FBL - Ikon
latte is offline        Reply With Quote
Old 06-05-2009, 12:59 PM   #4
fast400
on the spektrum recievers the throttle is in the 2 port.
battery) open
thro) esc
aile
elev
rudd
gear
aux 1
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote
