Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > RCDN 500 Nitro Conversion
RCDN 500 Nitro Conversion R/C Depot Hobbies RCDN 500 Nitro Conversion Kit Support
Old 06-08-2009, 04:15 PM   #1
crash-alot
Default Heli Balance / COG
Is your 500n nose or tail heavy?
Mine is definitely tail heavy. I've moved the rx battery as far forward as possible with little difference.
I would preferred if it was a nose heavy especially if you go inverted...
Outrage Velocity 50 FBL - OS55 - Align DS610, BeastX + DS650, MGP, Perfect Regulators Igniter Push Button Glow and Flighttech 8A regulator
T-Rex 600NP- OS50 - Align DS620, Spartan + DS650, MGP, SwitchGlo and Ely.Q reg
T-Rex 450SE V2 with CC45 esc
crash-alot is offline        Reply With Quote
Old 06-08-2009, 06:05 PM   #2
Gernejr
Show us some picture maybe we can help you out. Mine is perfect from full to half tank and i run a 8900 tail sevro..
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote
Old 06-08-2009, 08:11 PM   #3
george0079
Same here.
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote
Tags
balance, cog, heavy, nose, tail
