Old 06-08-2009, 09:40 PM   #1
nashiem
Default tail not staying stright
I have a msh protos and a trex 450. along with spartan gyros for both. when I try to do certain moves lets say a forward flip hard while moving forward, on both helis the tail kicks out to one side. Does this mean I have to turn the gain down a little bit. only fly in idle up, so my throttle curve is flat 90 on both. if it is not the gain, what else could I do to correct this problem.
Thanks guys
nashiem is offline        Reply With Quote
Old 06-08-2009, 10:00 PM   #2
Slyster
I would say kick the gain UP until you get tail wagging.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 06-08-2009, 11:22 PM   #3
rccardude04
Turn your radio's rudder dual rate down quite low so that you don't have much pirouette rate. See if it still kicks.
I'll bet your thumb is moving over during the flips and inputting accidental rudder.
-Eric
Bergen Gasser EB ~ GY611 ~ DS8611As ~ Raja's Jewel Generator \\ RXCharger Free since 2008!
TT Raptor 50 Titan ~ Slowly becoming FBL
BEAM E4 ~ 6s ~ ICE Lite 50 ~ Scorpion 1630KV ~ Spartan DS760 ~ HS65MG/HS5084MG
rccardude04 is offline        Reply With Quote
Old 06-08-2009, 11:34 PM   #4
Slyster
dual rate? You mean RUDD endpoints. That's what controls the piro/tail rate... try 90%
Pete Team Outrage.
Old 06-08-2009, 11:39 PM   #5
rccardude04
Dual rate also controls piro rate.
I set my end points (travel adjust) to 100% or 120% or whatever I feel like at the time, then increase/decrease dual rate as necessary to get the desired piro rate in a given flight mode.
You could even set an auto dual rate so that you have, say, 20% dual rate in idle2 for flip practice, and then 100% in idle1 and normal so that you still have adequate tail control when necessary.
-Eric
Old 06-09-2009, 03:30 AM   #6
markleyland
Try putting 5 - 10% expo on your rudder which will help to not make rudder inputs while doing your flips ect... I have the spartan also and nothing budges it, and that's no exaggeration, it's the best thing I bought for my trex besides the Jazz. Running a govenore also helps a lot. Make sure that your tail belt isn't too loose. When I first setup the gain it was fine for hovering but I found that when I was making fast turns in ff figure 8's I was getting a reving sound from the tail, turning the gain down solved that problem. I have actually snaped my tail belt having too much gain with this thing.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 06-09-2009, 06:36 AM   #7
JoelKatz
Low head speed. Tail belt/pulley slipping. Insufficient gyro authority over the pitch slider.
AMA 603884
JoelKatz is offline        Reply With Quote
Old 06-09-2009, 08:59 AM   #8
Slyster
OK.. am I correct .. with dual rates.. This is the basically changing the endpoints to 2 different settings using the switches? Nothing more?
Pete Team Outrage.
Old 06-09-2009, 09:03 AM   #9
jlharv
+1 on the rudder expo. Since I put in some expo, I get a lot less unintentional tail rotation.
John
nCPX ,mCPX BL, 130x - T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is online now        Reply With Quote
Old 06-09-2009, 09:04 AM   #10
rccardude04
I guess you can think of dual rates as end points that are switch-selectable with preset amounts.
-Eric
Old 06-09-2009, 09:08 AM   #11
JoelKatz
On most radios, you can set the end points and expo for dual rates. So you can use dual rates to have a low-expo mode and a high-expo mode (with or without different endpoints).
Some people use dual rates to have a high-expo and low-expo rudder setting. The low-expo is used for precision flying and the high-expo for more extreme flying. The high-expo setting lets you keep the tail straight through flips and rolls without being thrown off by accidental bumps in the rudder stick during collective changes. The low-expo setting makes it easier to do precision rotations at lower forward speeds.
AMA 603884
