Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 06-08-2009, 11:12 PM   #1
Bluerocktj
Default Replacing Pinion on BCPP2
I'm doing some crash repair and was wondering how you get the old pinion gear off of the main motor. The teeth got a bit mangled in the crash. I tried using brute force to get it off, but the whole shaft moved inside the motor. I hope I didn't ruin anything. I'm also upgrading to the microheli autorotation gear at the same time.
Thanks!
Bluerocktj is offline        Reply With Quote
Old 06-09-2009, 09:47 AM   #2
WickedDragon
You need a gear puller..... most hobby shops have ones that will work.
Doug Bonham, WickedDragonRC
Gravity isn't just a good idea, it's the LAW!
TRex450SE DFC; TRex450Pro DFC; TRex500 DFC Pro; TRex600N DFC's; CHP-TRex600eDL DFC; Trex700e DFC Pro
WickedDragon is offline        Reply With Quote
Old 06-09-2009, 11:09 AM   #3
Bluerocktj
Cool thanks! I'm stopping by Hobbytown after work to pick one up.
