Old 06-15-2009, 01:42 AM   #1
dawin2122
Default battery straps
hi guys somebody know where can i buy this battery straps?
dawin2122 is offline        Reply With Quote
Old 06-15-2009, 02:28 AM   #2
Vinci
The itemnumber is H60054T and they are straps for the T-rex 600. I've just bought a few at Fast-Lad.co.uk . Try a search on google, this is really common stock, maybe even your LHS has them.
Vinci is offline        Reply With Quote
Old 11-06-2009, 08:24 AM   #3
robl
how do you use them on a 500? I have one of those straps, but can't get it to work on the 500, way too long and because its velcro, you can't cut it down.
robl is offline        Reply With Quote
Old 11-06-2009, 10:29 AM   #4
Sake
It works about 1 1/2 " of contact just wrap it around
Sake is offline        Reply With Quote
Old 11-06-2009, 02:54 PM   #5
Stolpe
I use one of them, but I also use one JR strap.
/ Stolpe
T-Rex 450SE V2 mini V-bar, T-Rex 500ESP V-bar, HB CP2, Blade mSR
Spektrum DX8 radio + Raydiowarm
Hyperion EOS 0615i Duo III + 400W 24V 16,7A power supply
Stolpe is offline        Reply With Quote
Old 11-06-2009, 04:32 PM   #6
lex7919
im lost why cant you cut Velcro?? scissors usually work great for me.
Alex
Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote
Old 11-06-2009, 05:04 PM   #7
robl
its the contact of the velcro, it only contacts in certain places.
Old 11-06-2009, 05:06 PM   #8
lex7919
oh ok thanks didnt know that, obviously lol
Alex
Stop by say hi :-)
Old 11-06-2009, 05:15 PM   #9
Vinci
Thumbs up
Just mount them the same as Stolpe does, works great
Atom 500 : DX7SE
Old 11-06-2009, 05:46 PM   #10
Bayward
Here is what I like to use. McMaster-Carr has it in different colors, widths and lengths. Just cut off the length you want. For Trex 500 batteries I prefer the 5/8" width, although various other widths work just as well. The two rolls pictured are from my latest order and each one is 15 feet long. Thirty feet of hook and loop, enough for quite a while.
Bob
Bayward is offline        Reply With Quote
Old 11-06-2009, 08:07 PM   #11
robl
i only want to use one and one mounted like that I don't think would hold. I really hate the 500 straps, anyway to save a buck I guess.
Old 11-07-2009, 12:52 AM   #12
cpeugnet
I got frustrated trying to find just the right length straps for my 450 and 500. I ordered the JR straps from RCHover and waited for 4 or 5 weeks because they were backordered (their website said they were in stock ). Anyway, I finally ordered something like 30 ft of hook & loop as well as a bunch of plastic cinch loops. If you can sew even a little bit, you can make exaclty what you want, when you want it. All of the raw material to make tons of straps cost me something like $20 and now I've got straps exactly as I like them. If I buy a different battery (different size) I can just make another one. Gotta love that.....
This is where I got my stuff: http://www.strapworks.com/ProductDet...?ProductCode=V
cpeugnet is offline        Reply With Quote
Old 11-07-2009, 02:53 AM   #13
Vinci
Allthough I understand your way of thinking, with a nice piece of velcro between the lipo and battery tray AND using one 600 strap the pack won't go anywhere, it fits like a rock. I made a picture of mine:
Atom 500 : DX7SE
Old 11-07-2009, 04:19 AM   #14
cgetman02
Default Cutting down straps
I purchased some of the "Puretech" straps and they ended up being way way too long. After thinking about it for a while I decided that instead of letting them sit in my flight box I would try cutting them down to size. It actually has worked out great. I'm not sure what style of straps you have but the Puretechs have a nonvelcro webbing section connected to the plastic cinching loop. I cut out a section of the webbing and lap glued the strap back together with contact cement. When I want something to stick for sure I usually resort to contact cement, not the water based version.
Cutting the straps down actually has worked really well as I could custom make the straps the length that works the best on my EXI 500CF. I have one strap that goes around the battery and through the frame and around the ICE 75 esc. The other strap just goes around the battery and the nose of the battery tray with the balance harness under it.
Hope this helps! Curt
cgetman02 is offline        Reply With Quote
