| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Hi. First time post. I've been lurking for a little bit. I'm a really* new pilot :|
I was thinking of replacing the stock gyro and have seen mentions of both the Assan GA-410 from HobbyCity as well as the G401B mystery gyro. Are there any thoughts on one vs. the other (or are they both worthless and I should be looking at another one?). What benefits will I get from upgrading to any gyro over the stock one? |
If what you are buying is not a lot better then stock only to upgrade again later so don't waste your hard earned. False economyies and all that.
The Blade is a really a good little starter and the only two items to upgrade are the cyclic servo which don't last and the tail that needs pinning down solid. A good tail set you only buy once so buy good. The Logitech Combo comes highly recomended, I use the Align GP750+DS420 combo works great and only set me back £104.64 inc shipping ($172), good value in my opinion. Hope this helps ![]()
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM. Blade400-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor. |
heliproz.com had the logictech 2100 and 3100g for about $110.00
#4 | |
there are alot of people useing the g401b, they are saying you need atleast a .07sec servo for it to affective though. i would do the g401b over the assan.
Crashs come easy Patience does`nt To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. retired the 3 year old blade400
I have the g401b and I use it with a HS 65MG 0.12 sec. It works fantastic. I am not into 3D or HS tail first flight but it holds a lot better than the 110 . My son has a G240 on his 400 with a HS 65 and he says mine holds as well as his. My cost less than $40 and his cost about $100 more.
Go here http://www.rcgroups.com/forums/showthread.php?t=956825 there is a massive threrd on this gyro and many very happy users. First post list tested / compatible servos. Hint: gyro sensitivity setting lead must be connected or it will not work. You must set gain in the transmitter and it does not use the less than 50 / more than 50 rule. I mention this as the instructions are vague and you must download them from the website. Last edited by everydayflyer; 06-17-2009 at 02:25 PM.. |
#6 |
I have two G401B's and they work much better than the G110, about as good as my Logictech 2100T.
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
#7 |
-TREX600NSP - TREX500ESP - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 917540 - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 1003 - |
#8 |
G401B ($36) and a Ino-lab tail servo($19) = a good value!!!
I love gyros!!! They're yummy!!! |
| Tags |
| assan ga-410, g401b, ga-410, gyro |
