Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-26-2009, 09:48 PM   #1
ping
Default average flight time and tanks per gallon?
Just wondering what your guys experience has been with flight times and how many tanks of fuel you can get out of a gallon.
I haven't run a nitro anything in 12 some years, I'm thinking of giving a nitro Trex 700 a shot.
ping is offline        Reply With Quote
Old 06-26-2009, 11:12 PM   #2
cbdane
About 8 minutes with around 0.5 inch left in the bottom after each flight. You can fill about 6 empty tanks with a gallon. With the fuel left in the tank, I get around 7 flights per gallon.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 06-26-2009, 11:26 PM   #3
AARNAL
Total time per gallon = 52 minutes
At $26 per gallon = .50 cents per minute!
Al
AARNAL is offline        Reply With Quote
Old 06-27-2009, 02:10 AM   #4
ping
Where do you get fuel at 26 dollars a gallon?
Old 06-27-2009, 09:35 AM   #5
Skarn
I just picked up a case of coolpower 30 at a funfly from hobbyhut for $90.
Skarn
Skarn is offline        Reply With Quote
Old 06-27-2009, 10:01 AM   #6
AARNAL
At the LHS. He gives me a special price!!!
Al
Old 06-27-2009, 06:26 PM   #7
ping
Next stupid noobie question, 15 or 30 percent fuel? I'm intrigued by this orange "slime" and may soon own a nitro.
Old 06-27-2009, 07:44 PM   #8
LONEWOLF2440
30% here around 8 minute dont wanna know how many tanks per gallon lol
LOGO 600 VBAR TREX 700LE
JR 9303 2.4
ILL BE YOUR HUCKLEBERRY!
LONEWOLF2440 is offline        Reply With Quote
Old 06-28-2009, 05:04 AM   #9
OTA
I have just been running 15% on mine due to the LHS were out of 30%. After some minor re-tuning, i am positively surprised how little difference there is, but the 15% is more prone to cause bogging. You need to watch you`re stick movements
T-Rex 650 CF / Scorpion 4025-630, 12SJive 80+HV,2 x TP 3300 6S V2, Radix 710SB,Super Stubz,Futaba 9451,Spartan DS760/BLS251.Quick UK swash and tail
T-Rex 700N, OS 91HZ, Hatori 939, Radix 710SB, BLS 451, 9254 for throttle, Spartan DS760/BLS251, Quick UK tail,
OTA is offline        Reply With Quote
Old 06-30-2009, 02:28 AM   #10
masu
Last time on the field I finally used a timer to check flight times. For normal forward flight (loops, stall turns, push overs, cuban eights etc) 1850 on the head gives plenty of lift and ample power as the YS engine seems to have a lot of torque. I got 10 minutes per tank. Engine MAX temperatures were 48 from the bottom and 80 from the head (27 degrees out).
I used to have a 600N but that heli had to have well over 2000 rpm on the head to feel powerful enough. With that one I got a bit over 8 minutes per tank because the engine was running high rpm. Difference in total flight time is only 4-8 minutes per gallon in my current flight.
But if you want to fly harder with a .90...
T-Rex 700NP, YS91SR/Kasama Header/SB19, GY611, ReactorX, BLS451, RevMax/9254
JR X9303
masu is offline        Reply With Quote
Old 06-30-2009, 11:10 PM   #11
MAXHSHV
i get 7 minutes to a tank. I like to leave a little extra reserve incase i have a really good flight or i pull a no brainer and do a dozen tic tocs on the last minute of fuel.
I don't care what anybody says even a fuel magnet will go dry if you do that,
about 7 to 8 refills per gallon, It's well worth the 20 to 30 percent in added fuel cost over a 600 nitro.since i got my pair of t700n's my 2 600n's hardley get any flying.
MAXHSHV is offline        Reply With Quote
Old 07-01-2009, 03:18 PM   #12
CeeveeSiN
hehe buy bulk! 20 bucks a gallon for CY 30.
last huge buy we did earlier this year 15% was 17 dollars a gallon and 30% was 20.
this was over a 40 case order though..
SAB USA Field Rep, Skookum Field Rep,
Team Lynx
Goblin 700, Goblin 630, Goblin 500
CeeveeSiN is offline        Reply With Quote
Old 07-01-2009, 03:59 PM   #13
ping
So can you run 15 then switch to 30?
Old 07-01-2009, 04:07 PM   #14
CeeveeSiN
sure.. you just got to retune the engine.
Team Lynx
Old 07-01-2009, 10:37 PM   #15
MAXHSHV
i got in on the cy 30 % at taledo $18.00 a gallon,makes flying a 90 very reasonable.
Old 07-02-2009, 10:04 AM   #16
RichardVita
I had only 6 minutes at 1900rpm (YS91SR) without header tank landed with 1/8 of fuel left in tank.
RichardVita is offline        Reply With Quote
Old 07-02-2009, 10:01 PM   #17
MAXHSHV
must be a heck of a flyer or running it really rich.I runa ys90sr at 1960 7 minutes and a 1/4 tank left lots of full(14degrees)pitch flying.and i thought i was running mine rich.Also no header tank.
