| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I am currently building a trex 700 and have heard of several people struggle with their main gear.
Just wondering if using the -1 gear solves this problem or can this still be an issue? |
i stripped one of the stock gears switched to the updated one and no problems since arounf 5 gallons ago
LOGO 600 VBAR TREX 700LE JR 9303 2.4 ILL BE YOUR HUCKLEBERRY! |
I definitely recommend the FAD Mod1.0 upgrade. Do it for peace of mind.
Have laser, will travel. |
For piece of mind add the align metal bearing blocks but most people who had problems stripping gears were set wit the -1 version.
SPEkTRUM DX8 TREX600NSP VStabi V5.3 / 55HZ TREX700N DFC/3Gx/ 105 HZ-R |
I was into double figures on the first size main gears, not changed one since going to the -1
#6 |
Team Taco VP
Mod 1 period in my opinion. I have seen -1 strip with or without metal bearing block. Remember the frames / blocks are not adjustable and some people have too much backlash no matter what. If you want to stay with stock gears then the Gforce adjustable block set is better than a metal block that is not adjustable. For now worries about stripping ever, go Mod 1.
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
So which FAD Mod1.0 gear and which pinion should be used on an 700E using a Scorpion 4035-560?
Currently using my third standard Align gear and destroyed a MH-TX7102MG as well in 5 seconds. Can alraedy see the bottom of the gear bag... |
#8 |
I suggest 11T if you're going for huge headspeeds, 10T for 1900-2000 range. I'm running the 11T with a 510kV motor, governed at 1950, with plenty of headroom.
#9 |
So would that be the FADT08 main gear or a different one?
#10 | |
#11 |
Great, so a FADT08 main gear and a Mod1.0 10T pinion on a 560kV motor should give me about the same headspeed as what you are getting with 510kV.
Any recommendations for the pinion like brand? Read the way some pinions are shaped/cut differs from the shape/cut of the FAD gears. There should be a separate "T-rex 700 Electric Helicopters" sub-forum... Sometimes confusing to see info which is only applicable to the N version. |
