| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Good day. just wondering how many turns in your needle do you have on you os .50 engine to get mac performance. Im using a 30% nitro and stock align muffler (came with my t6nsp)
This will vary based on elevation and ambient conditions. If you are breaking in use 1.5 turns out from fully closed. Burn at least 3-5 tanks with it at 1.5 turns out.
You will most likely end up 1 turn to 3/4 turn out after break in.
<<450SE V2, CC35, Kong Power 3S 25C 2200, 430XL, 401 w/9650, HS65MG, tail weight mod>> <<Blade MCX with glow-in-the-dark setup, carbon fiber canopy>> <<Yellow 600SNP, 8717s, 770 & 8900G, AR7100, Multigov Pro, Align 2 in 1(used for glow driver only)>> |
Seems like a lot of people favor the 30% instead of less. I can only get 15% or 30% around where I live.
T-REX 600 SNP: Stock Blades, OS 55HZ Hyper, Hyper Pipe, 9254 Cyclic , BLS251 w/ Spartan 760, Align 2-1, MultiGov w/Spektrum RPM backplate sensor |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I've been using 20% lately and have definitely noticed a loss of power. Part of the problem is the climate this time of year: hot. Nitro engines don't make as much power in high ambient temperatures. I'm seriously considering going to a seasonal approach: using 30% during the summer for the extra oomph and 20% in the autumn through spring.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
You can mix 15% and 30% 50/50 to get 22.5%.
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM. Blade400-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor. |
#6 |
Using 15% my low screw is 3/4 closed and my needle is a few clicks lean of 1.5 turns. With 15 my low end needs to be very lean or the engine dies at rev up.
#7 |
Saying that you're running 30 percent isn't enough. It depends on what fuel, particularly the oil percentage, as well as the weather, and a few other factors.
Start rich, 2 turns or so for 30 percent and tune from there for a clean running engine thats not too hot.
Andy AMA 77227 Jacksonville FL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
I recently broke in a new Hyper engine at 1 1/2 turns out using 30% and the fuel(Wildcat) was spitting out of the muffler. I have leaned it out some and now it runs better and I can get a little more flying time out of it.
#9 |
Can the performance be strictly determined by the running temperature? For example, if the temp on my engine is 220F when I land, should I therefore stop making adustments?
Or can you get a better running engine by adjusting the low-end and the high-end? For example, richen the low end and lean the high end to comensate? From what I understand it would not matter, once the engine revs past a certain point I thought it is majorly the needle value that is controlling the fuel flow.
#10 |
The low needle should be set for clean transitions. The best way to get it close is to put the heli in a hover to clear out the engine, land and pinch the fuel line and start counting.
If the motor speeds up and dies or just cuts out, the low end is too lean. If it runs for more than 4 or 5 seconds w/o speending up its too rich. A good way to tell if your motor is too hot is to take it up and flip throttle hold, if it settles right into a nice idle its in good shape. If it does that rat tat tat all the way down its too lean. 220 after you land and check the temp is probably a little on the warm side, I'd shoot for 220 in flight with 205 or so by the time you can land, spool down and shoot it with an IR
#11 | |
E-Flite Blade mCP X, Blade 130 X, Trex 700LE Nitro FBL Nitro, Trex 700E DFC, SAB Goblin 700, and more to come. JR X9503 2.4ghz |
#12 |
Tukkus, my brother-in-law has been flying competitive control-line planks for over 30 years and has owned over 150 OS 50s. (Some of those he purchased, rebuilt, tuned & sold.) He says if you want the engine to last the maximum time between rebuilds you want just a touch of fuel spitting out the muffler periodically. You can get better performance from there, but you will be rebuilding more frequently. Just an fyi...
#13 |
I have been checking the backplate on my engine for temperature with my finger ,,just barley warm. where are u guys checking the temp with a ir gun & what should the temp be ?
Blade MCPX Nano,Trex 450 pro ,Trex 600 NPS,Trex 700E To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#14 |
I'm running about 190 degrees measured with a temp gauge between the blue head and the back plate. I measure it as soon as the blades spool down. I can hold my finger on the backplate for about 5-10 seconds. Seems to be right from everything I've heard. I also have tried to pinch the fuel line as soon as it spools down to see the motor goes lean after about 2 seconds of pinching the line, and you want it to run about 5 seconds before dieing out. But I am mainly going by temp.
