| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Im using the stock pinion that came with the kit. 13T.
Im wondering how many are using the 14T. How much flight time is lost going from the 13T to the 14T and is the time loss worth the performance? All opinions appreciated. Thanks,
T-Rex 550E, T-Rex 450 Pro, T-Rex 250 SE, Blade MCP X, Funjet Ultra, 3DHS 41 Edge, DX7, BC6 |
14T is a bit overkill IMO. I had a 15T on there with a scorp -8 and it was too much even at 80% throttle. I went to the 12T to give it a try at 100% but imagine i'll settle with the 13T.
700N - Microbeast MSH Protos - Microbeast To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
14t will kill your motor and battery.
I think I guy on here was saying that after a flight with the 14T the motor was hot enough to boil water instantly
Daniel DX7 - Mode 1 TREX 450 PRO!! - GP750 & DS520 - HS65's - AR6100 - Scorpion -8, Align speedy |
That was me. I got a second degree burn when I touched it the first time. That means temps at least 150 degrees. I need to get a thermometer to see the temps I'm getting. Honestly though? I loved the performance I was getting, because when the head bogged down the extra head speed would keep the tail spinning faster, so it wouldn't blow out on tick tocks and stuff. Also, I think it might burned out the throttle channel on my receiver, just a heads up. When I get my receiver back from horizon I'm going to put on my castle BEC, and see if the problem continues.
