Go Back   HeliFreak > R/C Electronics Support > Airtronics Radios
Airtronics Radios Airtronics Radios Support
Old 07-15-2009, 09:59 PM   #1
apriliamille
Default rds and finless ccpm video 1
hey all. first choppe,r trying to do the set ups with servo arms and the swash etc etc following bob's videos
im stuck around the 8 min mark
where is this swash menu in the rds 8000. im having an interesting time trying to find it
if its not there how do i do what he is doing in the video
along with the beginning section where he talks about ensuring all the swash are at 50 percent
mike
IT'S A TRAP !! GET TO DA CHOPPAH !!!
Beam, Protos, Wildhare, 3DHS, Ritewing, Pau, X-factory
fueled by Powermaster, Thunderpower, Graupner
SD10g for planes, XG14 for heli
apriliamille is offline        Reply With Quote
Old 07-15-2009, 10:57 PM   #2
TMoore
The Finless video doesn't apply to the RDS 8000 as it uses mixing schemes not SWASH AFR like the radios that Bob is using.
What heli are we discussing?
TM
TMoore is offline        Reply With Quote
Old 07-15-2009, 11:11 PM   #3
apriliamille
i just started doing servo alignment and swash work on the hk 450 from hobby city.
also have a cnc helicopter in the build hanger after i cut my teeth.
i also noticed when i was working with it that when i flipped the right mode switch between 1,2,3. the swash would move vertically up and down a tad; how to cure this? or is this normal
sorry for the questions. planes i can flip through the rds like no tommorrow. now im trying heli and im completely lost
mike
Old 07-16-2009, 12:35 AM   #4
apriliamille
doh. figured out the swash movement when i throw the mode switch.
its adjusted with the mode button in the sub menu not by throwing the mode switch.
Old 07-16-2009, 06:17 PM   #5
apriliamille
ok home from work. i think i worked it out. swapped servo connections in the rx did a reverse here and there and it looks like its working.
ended up pushing up the pitch to 125 percent and still have more travel available. going to move it back to 100 and lengthen the arms to get more of it done mechanically. atleast that is what i think is the best approach
since this is my first attempt at heli. i can only hope the next copter (cnc3dx450) wont have difficulties. eventually want to get to a protos. has someone used an rds on the protos?
but by then hopefully ill have the coin for the 10c
