| Register | FAQ | PM | News | HF Locator | Groups | Blogs | Calendar | Mark Forums Read |
| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them |
#231 |
At first I was just going to have a text entry box to enter in a gear ratio. Turns out it's a big pain in the butt to get a keyboard to work properly on the iPhone. I went with the number of teeth because then you get an exact ratio even for ratios that would have repeating decimals (2 and 3 teeth instead of entering 0.6666667, for example). Would it be better to just have a ratio to two decimal places with the +/- adjust buttons?
The history can't be cleared, but it is limited to 100 items (drops the oldest when new are added). The app should work with a first gen iPod Touch, based on the fact that Skype works on it. You just need a mic.
MSHeli Protos Carbon FBL - Mini V-Bar, DS510/BLS251, Stock ESC/Motor Outrage Velocity 50 - V-Bar, YS56, DS610@8V/S9256, AR7100R, Edge 603mm Mikado Logo 500 SE - V-Bar, BLS451/BLS251, Jive 80+ HV, Scorpion 4025-630 on 10S, Edge FBL 603mm To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#232 |
Hi, I just purchased this application and it downloaded to my pc, I synch pc to iphone and the application is missing. Am I missing something? What am I doing wrong?
Copter X Hybrid Scorpion 22221-8, HS65Mg, 401, DS3500G HK-450 Pro 450M,MG90,401,9257 Trex 500 GF 500M, HS5245Mg,401,DS3500G , TT Trex 600 ESP 12S, CC85HV,CC Pro BEC,Scorpion 4085-630,Mikado 3012,DS610,GP750, DS620 T7C / R606FS / R617FS |
#233 |
do you have an ipod touch with no microphone?
did you buy via itunes application or some other way? have you bought and installed any other apps successfully?
Protos 500 (plastic): Hyperion 3026-880, Jazz 80, VBar w/ Spektrum sats, MKS all round T-Rex 450 Pro: Stock gear, Mini VBar w/ satellite, Edge blades T-Rex 450 SE V2: Scorpion -8, 35X ESC, HS65MG, GY401, JR3400G, AR6200, Zippy-H, powerpoles, Align CF, Beam swash... Tornado Coin-Op: Gray marble cabinet, Head Xtreme-Soft wraps, nasty snake shot |
#234 | |
#235 |
You need to install iPhone OS 3.0 or higher. The app uses some functionality that was added in that version of the OS.
#236 |
Ok, I will update my OS. Thanks for the quick reply, I will get back to you when Im done.
#237 |
Just updated my OS, working perfectly now. Just test it on heli soon (weather permitting). Thanks.
#238 |
There's a new version up which makes the nitro mode more reliable.
#239 |
just got my iPhone for this AP! how do i upgrade to a new version
TREX 250 SE, TREX 450 SPORT, TREX 600 LE 3G FBL, DX7 ama #933973 |
#240 |
Just go click on Applications in the iTunes sidebar and click the update link below the app listing. iTunes will tell you all the apps that have updates available.
Alan (just call me "Bum"; no need to be so formal) Compass Model/Nankin Hobby Field Rep Helis: Atom 500, Logo 500 (V-Bar), FBL Atom 6HV on the way. Memberships: AMA |
