Old 07-18-2009, 10:56 PM   #1
marco101
Default trainning gear for 500
everything setup the way it should be on my 500 , installed trainning gear on it to try to learn nose in , heli start to shake badley , hovers very well without them , any suggestions ?
marco101 is offline        Reply With Quote
Old 07-18-2009, 10:57 PM   #2
Slyster
Must be some resonance.. try increasing your headspeed by 10% on each position?
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 07-18-2009, 11:12 PM   #3
marco101
do you mean my trottle curve?
Old 07-19-2009, 12:50 AM   #4
marchambault
I hope you are not trying to fly with the training gear ...
Training gear is for training on the ground, not for in the air. The first 10 batteries your helicopter should not lift off, that's when you can use the training gear to learn to control it on the ground, preferably on a slippery surface like a wood gym floor.
Think about the downwash on the training gear, if the gear is not perfectly symetrical (even on both sides) then your heli will be very difficult to fly.
What sim are you using?
marchambault is offline        Reply With Quote
Old 07-19-2009, 01:35 AM   #5
JackdaWack
The point of training gear is learning how to take off and land... I would suggest the same a as slyster check your blade tracking, any vibrations are sure to be worse with gear.
Trex 500 Esp, CC Ice 75, Hyperion 1600kv, Gp750, Ds510's , Ar6200, DS650 tail mod.
DX7
Hyperion 250w 6s Charger, Hyperion G3 Battaries
ParkZone T-28 w/ custom flaps+retracts, Ar7000
6s RCLander F-16 - To scared to maiden
JackdaWack is offline        Reply With Quote
Old 07-19-2009, 02:33 AM   #6
lankey
If you've got the gain on the tail a tad high, even the smallest of wags don't half show up in the training gear... don't really see anything wrong with having them on for learning nose in on the heli. Might just save a dumb-thumb moment if you're landing that way!
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote
Old 07-19-2009, 09:17 AM   #7
marco101
my sim is realflight g4.5 ,
Old 07-19-2009, 09:19 AM   #8
marco101
im not planning to go flying with the gears , i jusy want to hover nose in and land again maybe 3 feet off thre ground
Old 07-19-2009, 09:36 AM   #9
Vinci
Why don't you practise nose in hovering on the sim until it becomes natural to you, then get some height and try it in real life. You can either just make a halve piro or make a halve figure 8 so that the heli flies towards you, then slowly slow it down and you'll be hovering nose-in
Atom 500 : DX7SE
Vinci is offline        Reply With Quote
Old 07-19-2009, 05:31 PM   #10
françois
hello,
maybe a lot of people managed to learn in few fly(+a lot of sim.).... But, to feel safe, i used to learn with this training gear (no resonance, only ~ 15$ ) and it helped me to avoid a lot of crash( around 80$ each!)
when i started to feel comfortable with the héli, i played with the training gear (landing exactly // to the ground, trying to find maximum angle ...)
and then took it of..... and never use it again.
of course i don't pretend this is the only way...
Name:	FP train-gear3.jpg
ID:	106667   Click image for larger version
Name:	FP train-gear2.jpg
ID:	106668   Click image for larger version
françois is offline        Reply With Quote
Old 07-19-2009, 11:32 PM   #11
dawin2122
francois where did you buy this training gear please if is possible a link thanks
dawin2122 is offline        Reply With Quote
Old 07-20-2009, 03:27 AM   #12
françois
i find all the parts in a kite shop
1 CF pipe diam 5mm (strong) cut in two pieces (black one)
1 GF shank diam 4mm(soft) to do the circle in one piece (white one)
4 plastic links .
nothing else, no glue, i just stuck it in the skid
Old 07-20-2009, 10:35 PM   #13
marco101
hi there can you send me the plan for the skids it will be great.
Old 07-20-2009, 11:20 PM   #14
FlightAddict
i would be interested too, if that is alright. thank you.
FlightAddict is offline        Reply With Quote
Old 07-21-2009, 06:47 AM   #15
françois
I hope that these photos will be enough to help you....
the circle is a one piece 2000 mm long(GF) and the carbon pipe are 690 mm(one 1500mm Carbon pipe cut i two!).... all dimension are standard.
I just stuck it in the skid, thanks to the flexibility of both the skids and the circle.
... and then.....to assemble
that's all
hope it's enough ... if not, don't hesitate, ask.
ID:	106892   Click image for larger version
ID:	106893   Click image for larger version
Old 03-30-2010, 09:58 AM   #16
robbie george
Default training gear
hi can you tell me where you got your trainig gear it looks great i live in england and just starting out in helis and am looking for some trainer gear like yours thanks rob
robbie george is offline        Reply With Quote
Old 04-03-2010, 05:49 PM   #17
Trooper
Try your local kite shop, they should have all the items you need.
Ian
Trooper is offline        Reply With Quote
Old 04-04-2010, 08:48 AM   #18
françois
Like "trooper" said, i bought all the parts in a kite shop.
François
Old 04-04-2010, 11:11 AM   #19
jauguston
I got this simple setup from xheli.com where I got my 500. Cost $6.00. You see a Trex 500 main gear peeking out from under the canopy and a home made 1/16" aluminum tail servo plate for a Hitec HSG 5084 MG.
jauguston is offline        Reply With Quote
Old 04-04-2010, 12:01 PM   #20
10inja
I made my own from parts from the LHS and target for the balls..
If the shafts are too long then it will vibrate, so maybe thats your problem and why the heli is vibrating, shorten them a tad and try..
I got away with making mine much longer than the above post
but basically, got two long carbon fiber hollow shafts, balls (much muhc bigger than the above post) from target, and I cut a rectangular piece of wood and drilled holes on all four corners and stuf the shafts in the holes.
10inja is offline        Reply With Quote
