Old 04-08-2010, 09:27 PM   #21
Trickle007
Is this training gear to big for a 500? http://www.helimax-rc.com/accys/hmxe2025.html
Trickle007 is offline        Reply With Quote
Old 04-08-2010, 11:32 PM   #22
Tahoe Ed
Here is what I built for my 500 I have not had any issues with resonance. I have been hovering at 3+ feet. Carbon rods, not tubes, pvc and ping pong balls all put together with hot glue and wedged in the landing gear. It is big, but I did not want a accidental blade strike.
AMA #844172 DJI S800 WKM Z15 Nex5N iOSD Data Link Waypoint DJI F450 Naza + GPS with 5.8gHz vTx
DJI Phantom with GoPro3, DJI F330 with Naza + GPS
Align Trex 550 with WKH, Trex 500 with Naza H
Tahoe Ed is offline        Reply With Quote
Old 04-09-2010, 01:56 AM   #23
Trooper
Tahoe,
Will that actually stop it from tipping over? Looks to be a bit too wide a stance.
Ian
Trooper is offline        Reply With Quote
Old 04-09-2010, 08:13 AM   #24
Tahoe Ed
So far no issues. Knock on wood. It did not prevent me from mowing the grass, early spring flying at a park before the grass was mowed, and striping my tail servo gears. I will have replacements today in time to fly on Sat.
Old 04-09-2010, 02:10 PM   #25
Berkely
Well, this is my "home made" training gear.
Carbon rods 8mm, ping-pong balls on the end & fixed in a fiberglas frame which can be bolted on the landing skids. An extra 300grams in total but because it's bolted on the skids, the CG is perfect.
Never mind the long bolts, they are already exchanged with shorter allen screws.
Best regards.
Berkely
Berkely is offline        Reply With Quote
Old 04-10-2010, 12:33 PM   #26
Trickle007
heres the training gear imma use i got it from heli max it for .30 and .50 size heli's and i cut it down to shorten the carbon rods and to make little lighter what ya think?
Name:	Trex 500 ESP.jpg
Old 04-11-2010, 08:42 AM   #27
TETE
I'm using this one and it's GREAT!!!
Tete
TETE is offline        Reply With Quote
Old 04-12-2010, 12:09 PM   #28
azarby
http://www.youtube.com/watch?v=14IMu...layer_embedded
Tete
Where can you buy these?
azarby is offline        Reply With Quote
Old 04-12-2010, 01:02 PM   #29
TETE
From this seller on ebay:
http://shop.ebay.com/sjimt390/m.html...&_trksid=p3686
Old 04-12-2010, 01:17 PM   #30
azarby
Thanks, found it an placed an order.
Old 04-12-2010, 07:55 PM   #31
T/CHunter2009
Training gear is fine to fly with, just make sure your balls are out of blade wash. I flew around quit a bit with training gear and it causes no ill affects in handling. It may even help you due to the extra weight for a while , It will be a bit more stable with the training gear on. Once you can fly around a field with them on and have no problems doing so, take them off and enjoy the new experience , Same thing as a kid that takes off his diapers for the first time. You can do it , Your a big boy now . Dont piss your pants now .
Blade 130X : Bilnged out with Lynx & Microheli Metal ./ Batteries : Zippy Compact 500mAH / Glacier 450mAh /Eflight 300mAh iCharger 206B, P.S 350 power supply. Spin 8000kv motor.
T/CHunter2009 is offline        Reply With Quote
Old 04-12-2010, 10:25 PM   #32
232323
I ordered these too. Very well made...best I've seen.
232323 is offline        Reply With Quote
