Old 07-25-2009, 01:32 PM   #1
Jacket60
Default throttle signal loss protection
Anybody know if the align esc (RCE-BL60G) that comes with the trex 500esp has throttle signal loss protection, and if so, in what form.
Jacket60 is offline        Reply With Quote
Old 07-25-2009, 07:40 PM   #2
lex7919
no im affraid it doesnt but dont ask how i know this
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote
Old 07-25-2009, 11:18 PM   #3
Jacket60
OK, thanks. Do you know how the motor responds when the throttle signal is lost?
Old 07-26-2009, 12:59 AM   #4
Slyster
Thats totally up to your reciever. I have the spektrum system... and I set the failsafe (signal loss) to just shut down the motor.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 07-26-2009, 01:17 AM   #5
jhheli
Set my failsafe for center stick so if power is loss it wont have negative or positive pitch.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote
Old 07-26-2009, 02:10 AM   #6
Slyster
thats a good idea... but what happens to it if you drop your radio and break it? Will it keep flying for 3 more minutes?
Old 07-26-2009, 11:39 AM   #7
Jacket60
OK, now suppose hypothetically that all power to the receiver was suddenly lost. Does the ESC keep driving the motor?
Old 07-26-2009, 01:20 PM   #8
kyalamikid
That depends on your radio. On the Spektrum stuff I use, you have a failsafe position that you bind the receiver to. If you bind failsafe with throttle hold on and collective at mid position, then the blades will hve zero pitch, and the motor will be off.
Given your hypothetical situation, the power to the receiver actually normally comes from the ESC BEC circuit. So zero power to the receiver means that either:
1/ You have toasted your ESC.
2/ You have cut through the power wires from the ESC.
Both the above situations the ESC would not be getting current from itself (BEC circuit), which would case the ESC circuit to shutdown, as the ESC should disarm.
Logo 500SE, Gyrobot 900, Jive 80HV, BLS251, Scorpion 4025-1100
Trex 500, I2 FBL Head, JR3517's, Gyrobot 700, JR8900G, CC ICE75, Scorpion 3026-1400
Trex 250, Flybarless, Gyrobot 900, Innolab 201
kyalamikid is offline        Reply With Quote
Old 07-26-2009, 01:57 PM   #9
azheliguy
I guess I was asleep on that day of class and not set this up on my DX7.
Do you just set the failsafe position to what you want to happen during bind?
T-Rex 600 ESP 12s, V -Bar 5.0 , Scorpion 4025-630, 610's, 8900G, CCIce 80HV, Hercules Bec
azheliguy is offline        Reply With Quote
Old 07-26-2009, 04:37 PM   #10
Vinci
Did you ever tried to get it into failsafe position? I did on both the DX6i and DX7 with AR6200 receiver (newest firmware). For some reason it just keeps the last known position of the servos and doesn't return to failsafe/binding position, I wonder if it's just me ...
Atom 500 : DX7SE
Helicanopy.nl
Vinci is offline        Reply With Quote
Old 07-26-2009, 07:50 PM   #11
another_finn
No, that's the way it works. Both the manual and the Spektrum website are really ambiguous about this feature, but these threads clear it up nicely:
http://www.helifreak.com/showthread.php?t=28840
http://www.helifreak.com/showthread.php?t=72929
Mika
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote
Old 07-27-2009, 06:18 AM   #12
Vinci
Thanks for clearing that up for me !
Atom 500 : DX7SE
Helicanopy.nl
Old 07-27-2009, 07:29 AM   #13
J-S-Q
That's true except on the throttle channel where it will move the servo to your bind position.
J-S-Q is offline        Reply With Quote
