Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC > Outrage G5
Outrage G5 Outrage G5 Helicopter Factory Support Forum
Old 07-30-2009, 01:02 PM   #1
geoff200
Default Outrage 1700KV Bearing Replacement
Re Outrage 1700KV Bearing Replacement:
Are there any instructions on how to do this? Is it a similar process to replacing the bearings in the scorpion -8 motor?
Does anyone know what size the bearings are, how many etc?
Anyone else felt the need to do this?
My heli has started to get noisier and make a screaching noise, I wondered if it might be the motor bearings. In the past I replaced the scorpion -8 bearings with ceramic ones and it quietened it down quit a bit.
Any comments/experiences welcome.
Cheers Geoff.
I haven't a clue what you just said, so here is a rabbit with a pancake on its head.
Trex 450 SE V2 with Outrage G5 Head, Tail, 1700KV Motor, X3D Paddles and 6S Packs. 11T Pin, DX7, HS-5065MG's, AR6100e, GY401+DS3500G, Jazz 40-6-18, 80% TC, K+B Tail blades, Rotorworks 350 CF Blades. +/-12 Col, +/-7 Cyc. 520 packs flown, 13 crashes.
geoff200 is offline        Reply With Quote
Old 07-31-2009, 09:38 PM   #2
Raven_darkcloud
The motor separates easily with the pinion off. Look at the magnets too. If you need to change the bearing then put the new one in the freezer and use a soldering iron to heat the case by the bearing to get the old one out. Once removed put a thin layer of bearing retainer where the outer race wall will sit. Insert the new one fresh from the freezer.
Team Outrage
OPM - Fly it like it aint yours!
JR X9303 2.4 Baby. I have felt the difference and I like it!
Don"t make me list 'm all !
Raven_darkcloud is offline        Reply With Quote
Old 08-03-2009, 11:19 AM   #3
Fatdaddy
Default Main shaft
Just wondering, Have you checked your main shaft bearings?? Could be them making the noise. My G5 in new, about 20 packs thru and I'm a beginner. I noticed right away that my main bearings had a lot of play, forward and back!!! Not up and down!! So much that I'm gonna replace them and I'm wondering if anyone also has this issue???? If so I would get new bearings somewhere other than the G5 replacements.
Otherwise Man I really LOVE this heli!!!!! Un godly power!!!! Handling is great but the power WOW!!!! AND long flights!!!!
Blade mSR, HBK2 Xtreme
Outrage G5
EXI500, HDX500, Esky 900
E-Smart CF Pro, Full Metal E Smart, Outrage 550
G-Smart. Pegusas
Fatdaddy is offline        Reply With Quote
