Old 08-03-2009, 05:53 PM   #1
Allen Sullivan
Default 450 Pro tail servo
I'm installing the 65MS's, 401 Gyro - however my question is what would you use for the tail servo. The one I was running on my Blade 400 is way to small for the tail servo bracket. What would be a good match for the 401?
Allen
Trex 550
Trex 500 ESP
JR 9503
Allen Sullivan is offline        Reply With Quote
Old 08-03-2009, 05:55 PM   #2
N0FEAR
Futaba 9257 will work and works well when paired with a 401.
Rave 450 FBL
Rave ENV FBL
CurtisYoungblood.com - Field Rep.
N0FEAR is offline        Reply With Quote
Old 08-03-2009, 06:09 PM   #3
Allen Sullivan
Thanks - I was hoping the one I had would work but I can put 3 of them in the tray. Wasn't sure what would fit in the tray and work with the 401
Allen
Trex 550
Trex 500 ESP
JR 9503
Old 08-03-2009, 06:22 PM   #4
str8huckin
+1
Outrage 550 Hv85amp, gp750, 9254, bls451's,
Trex 500 stock esc, gy spartan, bls251, 9257's
Trex 250 super combo , hs 5084
trex 450 PRO w/ 9257& scorpion 8 cc45 ,410m's
Trex 700LE all stock gp pipe
str8huckin is offline        Reply With Quote
Old 08-03-2009, 08:17 PM   #5
Buffaloirish
I'm using the 9650. It fits and seems very solid.
~ Derick ~
Buffaloirish is offline        Reply With Quote
Old 08-03-2009, 09:13 PM   #6
Heli Davey
I will go with the s9650,never had an issue plus you can run it a 6 volts!!!!
TREX 500ESP*GY520*S9650*
TREX 600NSP*JR-8717*GY520*JR-8900G*
TREX 700N LE*91HZ*DS610*GP750*DS650*COOL POWER 30%*DX7
Heli Davey is offline        Reply With Quote
Old 08-03-2009, 09:32 PM   #7
brain
-agree with all above comments, but if you have time(of course some knowledges ), get the 9650, open the case and after that change the nilon gear of 9650 by the metal gear of 9257(optional). Now you have the tail servo 9257 but running at 6v, very strong and quick!
-Logo 600, Full size Blueline 5.3 + BLS 251, Cyclic Fu BLS 252 powered by Life 2s 6.6 V, HK III 4035 - 500 kv + Vbar Gov, YGE 120 HV
brain is offline        Reply With Quote
Old 08-04-2009, 06:15 AM   #8
Allen Sullivan
Thanks everyone for your help!
Allen
Trex 550
Trex 500 ESP
JR 9503
