Old 08-07-2009, 08:04 AM   #1
ttruttmann
Default Throttle Curves - does this make sense?
I'm trying to avoid any sudden RPM changes when switching from normal to IdleUp1. I noticed that if I was in hover - somewhere between center and 3/4 stick - and switched to IdleUp1, that it would jump.
I'm trying these settings:
Normal 0-50-65-80-95
IdleUp1 95-80-65-80-95
This makes the power curve (line) identical above center stick...is there any reason not to fly this way? IdleUp2 will still be flat. Thanks
TJ
- MT 325SE | DS287mg | GY401 w/9257 | Beam Carbon Tail Pushrod
- Trex 250se | D201HB | GY520 w/3500 | FS Carbon Tail Pushrod
- FBL UH-1 Huey | Thunder Tiger kit with RJX head & Skookum 720 - Current project
- JR 9303 TX
ttruttmann is offline        Reply With Quote
Old 08-07-2009, 08:17 AM   #2
jockstrap
the jump may actually be a change in pitch not throttle..
My 450s change HS on idle-up but do not jump in height at all...
There is a little kick in my tail thou on my new 450 pro as the HS chages quite a bit on that one.. but once again, no change in helight..
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote
Old 08-07-2009, 08:28 AM   #3
ttruttmann
hmm...my pitch curves are identical above center stick. It seems to reason that if you're at a given pitch...say 3 degrees at hover...that a sudden jump in headspeed will generate more lift. Maybe it's just more noticeable on my little 250 than on your heavier bird?
I see you have some smaller helis too...can I ask how you have your curves set up for them?
TJ
- JR 9303 TX
Old 08-07-2009, 08:33 AM   #4
halley
Those throttle curves have an identical center stick. Yes. That does what you want.
But the curves seem really low. 65% throttle on the stock equipment is not enough for a good response. I'd make your common point at least 80%.
halley is offline        Reply With Quote
Old 08-07-2009, 12:06 PM   #5
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
Forget all that... set throttle to 100% and go balls-out until the battery dies
Jasmine2501 is offline        Reply With Quote
Old 08-07-2009, 12:30 PM   #6
ferret30
You really don't want to have throttle changes past mid stick for normal mode, and also you don't want a v-curve for idle up. Many people on this forum have found that the 250 wags/kicks on throttle changes.
So use flat throttle curves, something like:
N: 0-80-80-80-80
1: 80-80-80-80-80
2: 90-90-90-90-90
Also, for normal mode, having your throttle and pitch changing around the hover point (i.e. 65%) makes the heli especially jumpy. When you move the stick down, the headspeed drops *and* the pitch changes, which makes it drop fast. By keeping headspeed constant and only changing pitch, the heli is more predictable and flyable.
ferret30 is offline        Reply With Quote
Old 08-07-2009, 05:05 PM   #7
ttruttmann
Thanks! I completely rebuilt the heli profile in my DX7 last weekend and I was suddenly getting a wag...I think we should start a list of things that don't cause a 250 to wag...
Maybe these new throttle curves are the culprit!
Hopefully I'll have a nice weather day this weekend to try it out.
Thanks everyone!
TJ
- JR 9303 TX
Old 08-07-2009, 06:08 PM   #8
Jasmine2501
That would be a very short list... all I can think of is Tuesday.
Old 08-07-2009, 07:34 PM   #9
ttruttmann
hehehe!
TJ
- JR 9303 TX
Old 08-08-2009, 05:47 PM   #10
helidude3
sorry, but what?!?
T-rex 250 Super Combo w/ hs-65mg's
Blade cp pro: spectrum receiver, BL main, DD tail, Gyro
www.bladecpupgrades.co.nr
Blade cx2
E-flite 4-site
helidude3 is offline        Reply With Quote
Old 08-08-2009, 10:42 PM   #11
Jasmine2501
Originally Posted by helidude3 View Post
sorry, but what?!?
http://en.wikipedia.org/wiki/Deadpan
It's just my style I guess.
Old 08-08-2009, 11:13 PM   #12
ttruttmann
<grin> as if your sig pic doesn't say it all...my puppy gets that exact same expression occasionally, usually when he's about to clear the room
TJ
- JR 9303 TX
Old 08-11-2009, 08:15 AM   #13
jockstrap
@ttruttmann - here are my t-rex250 curves
250 = stock motor, 16 tooth pinion, 410 servos, spartan 760 gyro 3000g tail servo
batt = zippy 20c 800mah, align 800mah 20c
blades = align 205D carbons
Throttle:
norm: 0,40,65,75,85
st1: 100,inh,80,inh,100
st2: flat 100%
pitch:
norm:45,inh,50,inh,100
st1: 0,inh,50,inh,100
st2: 0,inh,50,inh,100
Old 08-27-2009, 01:14 PM   #14
ttruttmann
N: 0-80-80-inh-80
1: 80-inh-80-inh-80
2: 100-inh-100-inh-100
I've been playing around with these and you're spot on that that higher headspeeds improved stability. I did find that I could hear my headspeed drop off a bit as the rotor pitch bit into the air.
Now I'm trying:
N: 0-40-80-inh-85
1: 85-inh-80-inh-85
2: 100-inh-95-inh-100
TJ
- JR 9303 TX
Old 08-28-2009, 07:16 PM   #15
TMoore
N: 0-80-80-80-80
1: 80-80-80-80-80
2: 90-90-90-90-90
I see no reason to use a flat line curve on the throttle as this elimnates the head room that the esc needs to absorb pitch changes. My tail doesn't wag and I'm running 3 different flight modes depending on the batttery I'm running and its power capacity.
TM
TMoore is offline        Reply With Quote
Old 08-28-2009, 09:38 PM   #16
watdazit
sorry, but what?!?
It's a sense of humour thing, either you get it or you don't. I like it Jasmine, keep them confused.
A geriatric flier pushing the brain cells and reaction time.
RC addict with lots of helis, planks and cars.
watdazit is offline        Reply With Quote
