Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters
Electric Micro/Mini Helicopters Electric Micro Helicopters Discussion
Old 08-08-2009, 02:07 AM   #1
Stealthlude
Default EXI 450 V2 Clone Kit... Missing Parts?
Anyone else buy the 450 EXI clone CNC head version for $50 from xheli?
I was in the process of mounting the servos and realized from the Trex 450 manual im missing these little plastic washers that go on the other end...
Was this included in your kits?
Not sure if it was supposed to be there...
Stealthlude is offline        Reply With Quote
Old 08-08-2009, 03:29 PM   #2
blvdbuzzard
I threw them away, they were total junk. I used2X6mm screws and 2mm hex nuts and loctite to mount the servos. The plastic hex nuts have never worked for me.
The one I did put together the EXI kit did not come with them.
Dru.
blvdbuzzard is offline        Reply With Quote
Old 02-25-2010, 11:52 AM   #3
phoenixheli
They dont give you proper screws for the servos. After I CA'd the screws a few times, the servos are mounted rock solid. If you buy exi servos, they come with the big mounting holes on the servo that require a bushing and a sleeve to install correctly, but they do not provide them. You can get them anywhere that sells futaba or hitech. Their servos are fairly decent otherwise.
Thumbs Only!
phoenixheli is offline        Reply With Quote
