Old 05-09-2012, 01:26 AM   #881
kittiwat1
Thank you. So the position mode is initialized as soon as the heli lifts off up tthe ground up too 6 feet then then the other mode takes over.
kittiwat1 is offline        Reply With Quote
Old 05-09-2012, 06:38 AM   #882
pril250
Yes but until the heli gets up to about a foot or two it will slightly 'dance',depending on gain, in the attempt to counter the ground effect.
Blade400
pril250 is offline        Reply With Quote
Old 05-09-2012, 11:02 AM   #883
kittiwat1
Thank you sir.
Old 05-09-2012, 05:46 PM   #884
Madhampster
Originally Posted by ece31316 View Post
How was it? Is worth the price? I'm torn between flymentor and CPII...
I have not given mine a lot of usage yet. I have only run 4 packs thru it and it works well. The weather has not been great when I am off so I have to use it more. What I see now is that it works great.
Madhampster is offline        Reply With Quote
Old 05-17-2012, 05:06 PM   #885
brushless55
Question
Will the Futaba GY401 work good with this system on my TRex600?
thanks!
brushless55 is offline        Reply With Quote
Old 05-17-2012, 06:40 PM   #886
Ivor Hill
thanks!
You would leave the GY401 connected as it is and FM would have no effect on it.
Ivor Hill is offline        Reply With Quote
Old 05-17-2012, 06:46 PM   #887
brushless55
Ok, I'm very new to this system..
I want to fly a Cannon 5D and keep things a bit more stable..
thanks!
Old 05-29-2012, 06:24 AM   #888
kittiwat1
Default Useable height for Balance Mode
I would like to know how high will the Balance mode works? Is there a height limit to it? I know that the Position mode will work up to 6 feet. Thanks
Old 05-29-2012, 07:30 AM   #889
pril250
As long as it is inside the earth's gravity force envelope.
Blade400
Old 05-29-2012, 10:51 AM   #890
kittiwat1
Default Balance mode/Horizontal mode
May I ask up to what altitude would the Balance mode or horizontal mode work? I mean, for example, can I fly the heli up to 50 meters high and the Flymentor will still keep the heli horizontal/level at that altitude or do I need to fly lower ? Thank you.
Old 05-29-2012, 12:42 PM   #891
CrazyCrash
Default FM /w Copterx 250SE
I am going to install FM on CopterX 250SE for my son. Can I keep all cylic servos and tail servo or I have to replace all servos with digital ones. I heard some servos do not work well with FM. please advise. thanks
CrazyCrash is offline        Reply With Quote
Old 05-29-2012, 02:21 PM   #892
Ivor Hill
There have been a few reports of servo's not being compatable but it's rare. I would not worry about it. It does not need digital servo's.
Old 05-29-2012, 02:57 PM   #893
CrazyCrash
Thanks. I pulled trigger and bought programming box too.
Old 06-03-2012, 07:39 AM   #894
kittiwat1
Default Problem with Flymentor
I had the Flymentor installed on my Belt CP V2 (450 size heli) by the shop which sells the Flymentor. I noticed on the first flight with it that the heli was going up and down like a yo-yo and I had to use the elevator/throttle stick to try to stabilize it. I was flying at about 4-5 feet from the ground. Is this an issue with the Flymentor or the heli itself? Many thanks for your suggestions
Old 06-03-2012, 09:49 AM   #895
pril250
Definitely not a known issue with FM, run it on two helis 400 & 600. Depending on what TX you are using you may want to look at your Throttle and more importantly pitch curves.
Blade400
Old 06-04-2012, 10:23 AM   #896
kittiwat1
HTML Code:
Definitely not a known issue with FM, run it on two helis 400 & 600. Depending on what TX you are using you may want to look at your Throttle and more importantly pitch curves.__________________
</DIV>Thank you, I can then rule out the FM issue. Anyway, I am buying KDS 550 and will tranfer the FM to this new heli. Hopefully, it would work out fine.
Old 06-26-2012, 12:50 PM   #897
giorgosmessa
Originally Posted by robl View Post
what does this mean? have you actually tried it?
hi all i have big problem with my flymentor
i connect all as the manual says but i have 4 red blinks
pls help me
giorgosmessa is offline        Reply With Quote
Old 06-26-2012, 06:42 PM   #898
pril250
pls help me
Are you plugged in to the RX and does it have power. More importantly are all the plugs in the right way. Is FM controller getting hot?
Blade400
Old 07-20-2012, 08:53 AM   #899
salience
Default Thin
I believe the air gets a bit thin for lift at the top of that range ;>)
Just finished installing a FM in a 500 Trex clone, much thanks to those who have contributed so many important setup details here. It's a flybarred but torque tubed HK500 with no mechanical "upgrades" as yet - I'll await some glitches to decide what to replace with a genuine Align or maybe Tarot part.
Getting ready for the first tests, but perhaps someone could suggest a throttle curve and pitch curve that would be appropriate for first trials by someone more interested to fly slowly and surely, rather than wild and wooly.
The FM programming box is a worthwhile item, imhp, maybe slightly confusing if you haven't done settings first with HeliBal. But post-HB, you already know all the settings so the box is straightforward and doesn't require awaiting the old laptop's lengthy bootup.
salience is offline        Reply With Quote
