Belt CP E-Sky Belt CP
Old 08-14-2009, 08:15 AM   #1
crash_harder
Default some advice please
so it was VERY exiting during that first spin up and battery... i have a couple questions though...
1. the heli shook and jumped around a good bit before it got up to speed? is this normal?
2. it was difficult to hold from drifting left, i mean really bad? is that normal?
all this while not leaving the ground. and i looked it over as far as blade tracking and balance, it seems to be pretty darn acceptable right out of the box... i was suprized.
thank you
brad
crash_harder is offline        Reply With Quote
Old 08-14-2009, 09:18 AM   #2
psilo
How tight are your blades? They should be tight enough that when you tilt the heli on it's side they stay in place but if you give it a little tap or shake they should drop. If they are too tight then you will get a lot of wobble until they straighten themselves out.
However, as Lankey said in your other thread, did you check the heli compared to the setup stickies? The chances are it won't be setup right out the box which can cause vibrations etc and to lean left/right etc.
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV
And a P51D plank......SSssssshhhhhhh!
BMFA & RCHA Member
[B][COLOR="Blue"]
psilo is offline        Reply With Quote
Old 08-14-2009, 09:34 AM   #3
crash_harder
i did check it and it seems ok, i very easily could be missing something as this is the first time i'm doing it and not watching it on this website... i have not done the blade check thing, i will do that first thing though... it seems they were pretty loose, not tight?? i'll check though and thank you
Old 08-14-2009, 09:35 AM   #4
crash_harder
sorry, so what your saying is that it should NOT jump around on a real slow spin up?
Old 08-14-2009, 10:10 AM   #5
GCK
+1 on checking your set up. Not likely your helicopter is set up perfect out of the box. Good enough to fly….may be. Good enough to fly well….probably not. A friend of mine struggled for almost a year with his Blade 400. He was getting ready to give up the hobby when I convinced him to let me have it for a week. The head set up was all out of whack. After spending an afternoon going through it from one end to the other I had it flying really good. He came and picked it up a couple of days latter. He can now hover with control and I feel he is just about ready to loose the training gear. He told me he could not believe how much better and easier it is to fly now. Point being is learning too properly set up your helicopter is the most important thing you need to accomplish in this hobby.
Oh and it is normal if your blades are not perfectly strait for the heli to jump around a bit on start up. Once they are strait in the blade grips then things should smooth out. As psilo pointed out if your blades are too tight in the grips it will jump around more as it will take more head speed to straiten them out. Also a slight drift to the left is normal on take off. This is do to the thrust from the tail rotor. You will need to add some right cylic to compensate for this. After a while this becomes second nature and you won't even notice this. But if its really bad then its back to checking your set up.
Good Luck
GCK is offline        Reply With Quote
Old 08-14-2009, 10:20 AM   #6
UAV_PILOT
Did you make sure your swashplate was level?
Blade 450 X
UAV_PILOT is offline        Reply With Quote
Old 08-14-2009, 10:27 AM   #7
crash_harder
thank you for the answers!! i will definatley be tearing into the whole thing when everything i have on order arives (tools, pitch gauge, charger)...
also, i have been using the search all morning looking for some info on some main blades that were cheap, around $5, and i just can NOT find the link to where to buy them... it's driving me crazy!! they were not wood, not carbon, some fiber something?? glass fiber maybe?? i see i will be needing about 2 more lipo's and some more blades PRONTO... thank you again for all the quick answers and help!! hopefully one day i can help out the noob...
brad
Old 08-14-2009, 12:07 PM   #8
another_finn
Maybe some of these?
http://www.hobbycity.com/hobbycity/s...&ParentCat=196
And while you're there...
http://www.hobbycity.com/hobbycity/s...idProduct=6306
Mika
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote
Old 08-14-2009, 12:21 PM   #9
crash_harder
that's it... CRAP... i just ordered 2 of those batteries from them and they are closed so i can't add the blades to my order to save on shipping.... GGGGRRRRRRRRR.
thank you!!!
Old 08-14-2009, 12:38 PM   #10
sutty
Sometimes you can modify an order if you are logged in as a member, with a profile. Maybe not with them, but often with other suppliers. Try creating a membership profile, and see if it shows you your pending orders. Last time I did this it linked my orders placed whilst I wasn't a member, to my newly created profile, based on my e-mail address. You might be lucky enough to do that too. Wasn't with them mind you, but you never know.
Good luck.
Cheers
Regards, Sutty
sutty is online now        Reply With Quote
Old 08-14-2009, 12:47 PM   #11
crash_harder
i will wait till 8-9 tonight and call them as they are 12 hrs ahead of me, or behind?? anyway i hope they will help me out. if not, guess i'll just suck it up...
thank you
brad
Old 08-15-2009, 04:36 AM   #12
Tomstoy
You're going to need a bunch of spare parts, too. Like main shaft, ( not Esky, go align, they're available just about everywhere ), flybars, blades, ( align wood are great ). Battery's, a good charger, and if the head is plastic, put in some overtime, you will have better success with a decient head and tail.
These guys here are GREAT, you won't find better advise about anything anywhere else. Go thru the threads and do your homework.
Good luck, and remember, THE GROUND IS NOT YOUR FRIEND.
Tomstoy is offline        Reply With Quote
Old 08-15-2009, 08:38 AM   #13
lex7919
These blades are awsome for the price perform great almost as good as Align 325Ds! and for 1\5th of the price
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote
Old 08-17-2009, 11:55 AM   #14
crash_harder
quick little update for ya'll...
i have put 3 full batteries under my belt, while hovering the whole time. i love this hobby... thank you all for the advise!! i have 2 more batteries ordered along with 5 extra sets of blades... got a good charger, now i just need to crash and see what to order next...
this is fun!!
brad
