My swash is set at 60%. Got +/- 10 on pitch. I want to set it to 12 deg. I increased swash to 70% and pitch didn't change. So I set swash mixes to 100%, still have + 10 deg pitch. Now, I see my servos increase their throw, but my pitch doesn't change. If I drop swash to 40%, then my pitch decreases. Why wouldn't my pitch increase when I increase swash mix, even though I can see the servos increase their throw?
I'm confused. ![]()
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. HeliSimRC Spektrum DX7, DX6i TREX 450, Blade 400, Blade CX2 Myspace.com/heliwhore |
Check the geometry of the servo horns to the linkages.
When the servo is centered and the horn is at 90 degrees, swash rotation turns perfectly into linkage movement. As the angle increases or decreases, it takes more and more swash rotation to produce the same amount of linkage movement. Once the angle gets close to 0 or 180, rotating the horn just moves the linkage forward or backward, not up or down. The solution is probably to increase the servo horn length, usually by moving the linkage ball to a hole further from the center.
-- AMA 603884 |
Sevo arm center to ball center you need 12-13mm to get 12degree pitch.
Scott Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's Last edited by life2short1971; 08-14-2009 at 11:23 AM.. Reason: .. |
Yes, I set all three so they are kept equal.
Boy your fast.LOL I changed previous post assuming you had.
Scott Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's |
#6 |
Joel, what you said makes sense. I'll check it out and see if the swash moves any higher or not when the servos throw more. If not, I'll replace the arms and extend the links out.
#7 |
I know this sounds stupid but I've read of stranger things happening with the DX-7. Try rebinding with the new swash mix value and see if that helps.
But if you see increased travel in the servo arms, that should translate into increased pitch, unless your swash is hitting the head block and binding. Wierd.
Warp 360 Spartan Vortex VX1 |
#8 |
I noticed that when I increase the elevator to 100%, the servo cage moves but the arms barely move at all. So yes, I need to move balls out on servo arms.
On side note, I increased pinion to a 13t (was 11t) and it handles the wind a lot better. But I had a booom strike.....see other thread.
