| 2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
Looking for a different mix for my 600n heli.
I'd like to be able to flip a switch (leave on) it would'nt affect my throttle setting while in id1 , but when i click the throttle hold switch it would cut the engine. (and if the switch was off and you used th hold it would act as normal) Why you ask. Well i want to get better at my auto's and the field i fly at is dirt. If i could have the engine off on the way down i could just set her down with little to no dust/dirt problems. I realize that there's no bailing out , but i've never bailed out yet so its a non issue for me. My importtant issue is going to be injesting dirt into engine. Possible on a dx7 ? or do i need a 9303 to do this ? martin
Logo XXtreme 8917 / 256HV Logo XXtreme 700 8917 / 256HV Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500 Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale |
You setup a throttle to throttle mix that cancels the throttle input and brings it to zero. That would cut off the engine... You assign that mix to a switch, and you would use it to cut your engine, otherwise use the throttle hold and you simply idle
As we think so we become. |
You may be able to tweak Bob's setup to suit your needs.
http://www.helifreak.com/showthread.php?t=45605
Helis - Raptor 30, T-rex 450SA, Blade 400, Blade CP, CX2, mCx Planks - GP Revolver, Seawind EP, Typhoon 2, Mini Pulse XT, T28 Trojan, SuperCub on floats |
Exactly! Why not just use the built in functionality to idle in HOLD and then if you want to bail on your auto for whatever reason you have the option.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se |
