Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-23-2009, 01:25 AM   #1
puma1824
Default Flybarless T700 / Mikado Conversion Questions...
Can someone using a Mikado FBL head conversion for the T700 measure the distance between center mainshaft and center of the blade grip control arm balls? Like the pic below. Furthermore, what distance from ball to ball on the servo arm/wheel are you running? What is your collective common and min / mix pitch at that setting?
Thanks in advance.
Team Synergy- YS Engines - Coolpower
puma1824 is offline        Reply With Quote
Old 08-23-2009, 03:14 AM   #2
Skint Eastwood
head ..... ball to centre 38
ball to ball .....servo 22
pitch +- 13
Have tamed the pitch down somewhat +-18 would be the max at this geometry
I use the skookum 360 and its electric if that makes any difference
sorry just read 'collective common' so i guess you want people with Vbar
Skint Eastwood is offline        Reply With Quote
Old 08-23-2009, 08:42 AM   #3
4cyclic
same here 10.8 mm on each side of horn, -13 to +13 pitch.
4cyclic is offline        Reply With Quote
Old 08-28-2013, 02:39 PM   #4
marke
hello i have a question on using this conversion-does the head shack when at 1600 to 1700 head speed? at 1800 rpm it smooths out but below that seemed very un stable--all is straight and tight but bad head shack.
thank you for any help
marke is offline        Reply With Quote
