Go Back   HeliFreak > R/C Helicopter Support > HeliDirect
HeliDirect HeliDirect HDX300, 450, 500, 550, 600 Factory Sponsored Support Forum
Old 08-30-2009, 11:52 AM   #1
neilg.
Default switching over --maybe--
so if i have the dx7, hs65hb servos, ar7000RX, 401 tail, s9257 tail servo, 3s 2200 lypos, it should be an easy transition to a HDX450SE V3?
how easy it it to adjust servo horns?
how do the aluminum parts hold up after crashes. just the normal stuff? i assume parts availability is not an issue?
neilg. is offline        Reply With Quote
Old 08-30-2009, 11:13 PM   #2
B2TheEYo
I have the 450.. The CNC is not an issue at all it's all 7075 aluminum. I've NEVER bent, broke or stripped one CNC piece on this frame, let alone scratched it.
It's totally worth it, an amazing heli to say the least.
Parts aren't hard to find, lots of 3DX/HDX suppliers.
B2TheEYo is offline        Reply With Quote
Old 08-31-2009, 02:42 PM   #3
Dusty1000
Hi Neil, My Sonix 450 is the U.K. name for the HDX450SE V3, I haven't had it long but can tell you that compared to the Blade 400, stability is absolutely awesome, I couldn't quite believe it the first time I took off - so if that's what you're looking for I'd say go for it. I do really like my Blade but you realise the difference in quality compared to the HDX when you open the box
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
