Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 09-02-2009, 02:33 PM   #1
Jaguar_5
Default LVC
Hey guys
Has anyone either used a voltmeter to check voltage or even better a charger that actually displays mAH put back into the back, and checked if using LVC is ok, or hard on the batteries?
LAHeli - Mikado - Henseleit - FASST
Powered by ProgressiveRC & Spyder Batteries
Jaguar_5 is offline        Reply With Quote
Old 09-02-2009, 04:19 PM   #2
RocketSled
The LCV comes on pretty quick, but the heli flies about the same until right up to the cutoff. I've noticed that sometimes if I try a restart after the cutoff, the voltage drops low enough the Rx stops working. The heli lands and the rotor continues to turn slowly even though I've chopped throttle completely. Batteries are slightly warm after a full flight. I'm too lazy to meter it, but I think the LVC is working about right.
RocketSled is offline        Reply With Quote
