Old 09-06-2009, 07:52 PM   #1
Water Viper
Default Grease on Collective Stick?
What kind of grease is used for the collective stick inside the DX6i to make smoother?
Trex 500 ESP, HK450, DX6i/AR6200
My YouTube
Water Viper is offline        Reply With Quote
Old 09-06-2009, 08:03 PM   #2
GunnyGlow
Shoot....WD-40 with a touch of 90W gear oil orta slick it up James Dean style.
JUST KIDDING. I would clean it and check the tension before I just lubed it. Or...mayybe you have an aircraft radio with a ratchet throttle??
GunnyGlow is offline        Reply With Quote
Old 09-06-2009, 08:30 PM   #3
cbdane
Stay away from petroleum-based stuff. It can slowly degrade the plastic. I suggest white lithium or silicone dielectric grease.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 09-06-2009, 08:34 PM   #4
ping
Put a piece of heatshrink tubing over the metal strap and use a silicone grease on it. Mine is super smooth with absolutely no notchiness.
ping is offline        Reply With Quote
Old 09-06-2009, 09:00 PM   #5
Water Viper
No ratchet action. Itís just a little sticky at times. Iím trying to learn inverted hover on the sim. When Iím inverted and input small collective, it sticks. I noticed it when hovering my Trex 500 but it was manageable. I figured I need to cure the problem while Iím on the sim.
How often do you replace the lubricant?
Thanks for the help.
My YouTube
Old 09-06-2009, 10:17 PM   #6
Guardian-1
I have the same issue. I lightened the tension and it helped alot, but still has a slight sticky feeling.
Guardian-1 is offline        Reply With Quote
Old 09-06-2009, 10:53 PM   #7
GunnyGlow
Or food grade silicone. If you get it all over your fingers....you can just lick it off.
Old 09-06-2009, 11:36 PM   #8
JackdaWack
u need to grease the bushing if anything, or replace it with bearings.RC Heli Forums - Spektrum DX7 - Step-by-Step Bearing Mod
Trex 500 Esp, CC Ice 75, Hyperion 1600kv, Gp750, Ds510's , Ar6200, DS650 tail mod.
DX7
Hyperion 250w 6s Charger, Hyperion G3 Battaries
ParkZone T-28 w/ custom flaps+retracts, Ar7000
6s RCLander F-16 - To scared to maiden
JackdaWack is offline        Reply With Quote
