| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Guys how many flights before do you guys get in before having to chang your servos? How do you know it's time to change the servos.
I have 339 flights on the servos in my T-rex 600N and had a weird thing happen this Saturday, where the elevator servo seemed to jump... Thanks for your help. Last edited by steffgiguere; 09-19-2009 at 09:50 AM.. |
Don't know which servos you are using but I would first check the gears and if they are good try and isolate the servo for a fault. It could be some other component is spiking the supply line, what is the tail servo?
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM. Blade400-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor. |
The cyclic servos are ACE DS1313 and the tail servo is Futaba 9256 with GY 611.
So does that happen now every time you switch her on or was it a glitch type of thing. Are you on 2.4Ghz.
If you have a servo that is consistently "jumping" "twitching" or "glitching" replace that servo most likely the servo pot. If it still does it, it could be a a bad solder joint on a connector pin in the receiver.
#6 |
It did it three during my last flight, didn't want to try to refly because I was afraid of crashing. What do I do now?
#7 |
Since you are already psychologically prepared for it, buy a spare servo, replace it with the suspected item and try a few hovers. If you think more then one are bad then it is time to replace. It all depends on confidence and budget really.
#8 |
Only the one was jumping, I will get another one and try changing it to see what happens.
#9 |
now that i was making some adjustements to my rexy i noticed that when my servos are in the center position (90 degrees) they seem to move a little, not much im talking about almost imperceptible, but you can see it !!
its that normal ?
Align Trex 600 Nitro Super Pro |Align governor | Align DS610's OS 50 Hyper | Sg Reactor X | Futaba GY 611 | Spektrum DX7 |
#10 |
yes that is normal with digital servos, thats why you hear the buzzing sounds coming from them.
| Trex 600 NSP | ds610's/ds620 | gy401/9254 | ar7000 | align 2-1 | multigov pro | hyper 50/ align pipe | | Align Trex 450 SE V2 | hs-65hb's | gp750/9650 | ar6100E | V3 head upgrade | 325 align carbons | align 430 XL/ 35x esc | |
#11 |
It is normally associated with the servo constantly hunting for the center but if it gets excessive that may mean the pots are getting worn.
#12 |
they doesnt move that much !! so i think it is for the center thing..thanks bro, thats what i tought...i wanted to be sure
#13 |
Well I think I found my problem. Before removing my servo I unattached all the wiring and noticed I had a extension and it was loose...do you guys think this could be my problem?
#14 |
I recommend using electrical tape on the connection to keep it tight. You'll want to test, test hover, etc. Better safe than sorry, but that could very well be your issue.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se |
#15 | |
