Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 09-14-2009, 06:26 PM   #1
derelict
Default Vbar Velocity
Hi All
This is my vbar'ed Velocity 50 including the config file and some pictures
Please be aware... that i haven't flown it YET with these settings!
Maybe it's of use for anyone.
some other pictures here: http://www.helifreak.com/showpost.ph...7&postcount=39
setup:
- vbar 4.0
- jr8717 on cyclic (6.8V regulated)
- scottgray reactorX regulator
- western robotics lipo monitor
- jr8900 on tail
- novarossi 57 engine and pipe
- futaba 9257 on throttle
- multigov pro
- switchglo
- rotortech 610 blades
- radix tail blades
- outrage flybarless head
- futaba 6008 receiver
Cheers
Marcel
ID:	115205   Click image for larger version
ID:	115206   Click image for larger version
ID:	115207   Click image for larger version
Never allow someone to be your priority while allowing yourself to be their option!
TRex600NSP:TT53,RDX600SB,Mgov/CSM,8717@7v,HS81,6100T/6100G,Hi-flow
TRex700Pro:YS91SR,RDX690,MgovPro,8717@7v,9254,DS760/JR8900,SB19/KASAMA
TRex450SEV2:2221-6,RTech320,CC60,HS65MG,401/JR3400G,CCBEC6V,3s
OutrageG5:1700kv,Ctec350,CC30HV,HS5065MG,DS760/JR3500G,CCBEC6V,6s
derelict is offline        Reply With Quote
Old 09-15-2009, 05:44 PM   #2
derelict
I've got the TX matching wrong... and therefore the swashsetup.
here is the updated config.... i'll post another version... once maiden flights and engine breakin are finished.... and everything is dialed in.
cheers
marcel
Old 09-16-2009, 10:15 PM   #3
watso
how is the flybarless working on the velo?
watso is offline        Reply With Quote
Old 09-17-2009, 03:36 AM   #4
derelict
lol.... if you could see the weather in switzerland for the past few days... you wouldn't ask that :-)
I did not have the chance to maiden it yet... due to rainy weather :-(
I'll let you know... and post the updated config files!
Marcel
Old 09-26-2009, 01:46 PM   #5
supa koopa
Hi Derelict,
how the hell did you manage to get 0 degree pitch at mid stick? The rods that came in my 575-9 kit are just too long. I've screwed the links all the way in, in fact too far on two of them, and I still have 3 degrees of pitch. If I drop the swash to 0 degrees the swash fouls on the collar. I have the balls all the way out on the blade grip arms and the head block on the bottom hole to the head is at it's highest. I lost count how many hours I've spent trying to sort this out. I may end up trimming the rods to get it to work.....!
Can anyone help a stressed out individual?
supa koopa is offline        Reply With Quote
Old 09-26-2009, 01:53 PM   #6
supa koopa
Angry
Well I think I've just answered my own question. After looking on helidirect it states they should be 61mm, well mine are 72mm and do not look anything like the attached image. That puts an end to me flying it this weekend. Now I am annoyed...!
Old 09-26-2009, 09:45 PM   #7
manos
http://www.helidirect.com/r50n901ss-...ty-p-13989.hdx
they got 72mm also
manos is offline        Reply With Quote
Old 09-26-2009, 10:45 PM   #8
Foxden
Try part # R50N575-9 the description say this
  • 2 x M2x61mm Linkage Rod
  • 4 x Plastic Ball Linkage
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote
Old 09-26-2009, 11:18 PM   #9
ChrisH
Nice work! What radio is that?
ChrisH is offline        Reply With Quote
Old 09-27-2009, 12:38 PM   #10
derelict
ok.... maiden flight done today.... the novarossi glowplug almost got me in thinking that the engine is running to rich so i leaned it out until the motor got too hot during breakin.
The problem i had with the glowplug was, that the engine just died suddenly on hovering throttle.... replaced it with an enya 3 and all is fine.
well... after motor breakin... and a short trim flight, all i can say is:
WOW!.... massive power.... stable flight.. fast and precise cyclic.
So my (second) setup i've posted worked out fine.... i might increase the rudder gain a bit.
@trexflyer02: it's a futaba 12fg
Greets
Marcel
Old 09-27-2009, 06:14 PM   #11
supa koopa
Foxden - that is the part number I bought and it had 72mm rods instead of the correct ones. In the end I had to cut the links down to get 0 degrees. I'm off to the lhs tomorrow to try and get some more correctly sized links.
I maidened my today also. Everything seemed pretty good apart from the damn wind which put a real downer on everything. I do have to say I was very nervous before the first lift off, but the vbar performed flawlessly.
Old 09-27-2009, 06:19 PM   #12
Foxden
Hmm, Call HD and let them know that the link size was wrong as they were made specifically for the FBL head
Clyde Fox
Port Charlotte, FL.
Old 09-28-2009, 12:29 AM   #13
ChrisH
Ah, ok, cool. Looked like the new 8ch ...
Old 03-30-2010, 10:10 AM   #14
beans07
Just starting my conversion to vbar.
Which hole did you use on the main grips? Looks like the middle one?
Synergy E7 + E5 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L ~ Gaui X3
beans07 is offline        Reply With Quote
Old 03-31-2010, 01:03 AM   #15
desert_flyer
Make sure that your sensor connector is secured with hotglue and it helps to add a dummy connector below to provide additional support...
desert_flyer is offline        Reply With Quote
