Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 09-16-2009, 04:00 PM   #1
Phoebe
Default Spektrum Receiver Question
Based on some stuff I'm seeing lately it looks like Spektrum might be obsoleting the AR6100 and replacing it with the AR6100e, which is the end-connecting config.
Has anyone used the AR6100e in the Blade? How/where did you mount it?
Phoebe is online now        Reply With Quote
Old 09-17-2009, 02:07 PM   #2
Phoebe
So you guys must be using the AR6100?
Old 09-17-2009, 02:40 PM   #3
n6nev
Default rx Pro 2
Yes, I use the 6100/pro 2 and a dx7 and am very pleased,
n6nev is offline        Reply With Quote
Old 09-21-2009, 07:28 PM   #4
helimonger
Which Blade are you referring to? B400, cp? On my 400 it is mounted in the rear with double sided tape and a zip tie. On my cp it is double sided taped to the mixer. I have had great success with that receiver on the cp. And yes the DX-7 rules. Just being able to set up your bird to your own preferences is a godsend.
helimonger is offline        Reply With Quote
Old 09-22-2009, 07:12 AM   #5
Phoebe
I'm referring to the CP family. The end-pin config of the AR6100e doesn't seem terribly compatible. I'm hoping that when I make the plunge the AR6100 is still available.
Old 09-22-2009, 04:47 PM   #6
helimonger
I use the AR6110e on all three of my cp's. No problem. But to make pin access the easiest I did mount it a little forward. It seems to work fine for me. Here are some pictures to better explain.
Best of luck
ID:	116460   Click image for larger version
ID:	116461   Click image for larger version
ID:	116462   Click image for larger version
Old 09-23-2009, 10:29 AM   #7
Phoebe
Helimonger,
A picture's worth a thousand words.
Thanks!
Old 09-23-2009, 10:32 PM   #8
helimonger
Anytime
