Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > Lama V3/V4 and Kob
Lama V3/V4 and Kob E-Sky Lama V3 and V4 and Kob
Old 09-17-2009, 06:38 PM   #1
B3master
Default which is the best swashplate for V4 lama?
Hi all,
wondering if you had experiences with more than one swashplate, i want the one with the most operational tilt angle, that way i can go to fourth hole on the servo arms
B3master is offline        Reply With Quote
Old 09-18-2009, 01:04 AM   #2
dayshaddow
hi there
i will be honist with you
the cnc is great swash while you are learning and crashing often as it wont seperate like the stock plastic one but once you are a master pilot with only the rare light crash then stick with the stock one..both performe the same(i know advertised otherwise)however i reckon i have clocked up around 2000+ hours of lama flyin time and still fly stock as it workes very well
both swashes have a limited amount of travle.the 4th hole isnt the holy grail of lama flying. either swash will run out of travle long before the stick on your transmitter dose..as mentioned before pushing the stick further than the swash ability to swing will cause servo binding
simple way to see is move the push rod to the outter most hole..now without throttle move the cyclic stick though its full range of motions..you will quickly see the servos are able to swing much more then the swash..typical you see servo horn bending or the swash arms bending under the load from the servo
antony
msr msrx tr250 hk450
2 planks
wat for foamy and eflite beast
1/8th Brushless LiPo Powered monster Truck and a maverick strada evo xt
dayshaddow is offline        Reply With Quote
Old 09-18-2009, 03:00 AM   #3
Rusty63
+1 Antony , Only metal parts needed are Innershaft Top. Eskycnc Top is fine . Anything else just adds weight . Keep this in mind if you have problems .
http://www.helifreak.com/showthread.php?t=124029
Esky Belt CP ,Futaba 6exhp , gy240, s3110 tail,
Lama v4 , cnc inner shaft ,Big Lama under bombproofing test.
The Twisters , Chinook , Black Hawk , Medevac hotrod , exten/shaft , pontoons .
The lil fun one . Walkera 43#b
Rusty63 is offline        Reply With Quote
Old 09-18-2009, 04:29 AM   #4
B3master
Thank you Antony and Rusty.
I have gone through that thread before when i notice the small pitch on one side of my swashplate im ready for it .
about the stock swash i belive I have previously heard it from u both that the best swashplate is the stock one, just seems to slipped my mind, and that it does have the most travel. I guess i can forget about 4th hole im not even gonna try i think with the 3rd im extremly near my stock swash limit.
im now just wondering if the metal ones (compared to each other) have different or similar travel, i did only order extended inner shaft and xtreme blades and 20mm shorter flybar, i know the rest is bling. but sooner or later the play within the blade holders has to go and i will need metal blade holders which will raise the CG and to make up for it will need the indestructable heavier landing gear as well as the metal swash, i hate to ADD weight, i would rather shift weight arround. but all these are adding weight, even the extreme blades, But least they make up for their own weight with the added pitch angle.
With the shorter flybar and extra weight on top (and after im forced into getting the metal blade grips).... im worrying already.... the thing gonna be very twichy
Old 09-18-2009, 10:54 AM   #5
dayshaddow
hi ya
lets start with the skids
http://cgi.ebay.co.uk/AFC-system-Lan...3286.m63.l1177
these wont break easily but are desighned to work with the extreme canopy..but i just used some small sizzors and cut a small section out of the canopy on both side to allow the canopy to be mounted..you will also need to make some new holes for the screws in the canopy as the origional ones will now sit a bit to high and the lower lades will clip the canopy when you start to spin her up
the metal blade grips well if you really feel the need then only use the extreme blade grips and not the ebay cnc ones as they are faulty
the grips when assembled are not square the ball joints can also freely move up and will ruin your helis stability
oh and as for raising the cog its a bad idea and will make it even easier for you to death roll you lama in a sudden turn/manover
cheers
oh and hi rusty hows it going
antony
hope this helps
antony
2 planks
Old 09-18-2009, 10:34 PM   #6
mnwizard
There are 2 different types of CNC swash plates. The most common one is a direct replacement for the stock plastic one.
The other type is the eXtreme brand. It has longer, higher control arms and requires a longer control linkage between the servo arm and the swash.
I have flown both types, and there is no difference in flight between either of the CNC types or the stock plastic one.
The CNC parts are fun to putz with and for adding a little bling, but with the exception of the extended shaft, they don't make the heli fly any better.
- Jack
Cranky old fart and charter member of ESO
Lots of Helis
mnwizard is offline        Reply With Quote
Old 09-19-2009, 09:29 AM   #7
B3master
antony
Howdy Antony,
I notice lots of play in the stock blade grips, hence i thought sooner or later i will be forced to upgrade to metalic grips like the xtreme ones, but the result with that upgrade that i fear is a higher COG, i didnt want to purposly raise the cog, im just mentioning its a bad side effect and hence to counter it i will need heavier landing skids.
i think ill be holding off the cnc swash unless it indeed comes apart, then i will fix it as spare and replace it with Esky cnc one, i thought there was an advantage with the xtreme one the esky cnc is available localy $12 i dont need to pay shipping or anything
Old 09-19-2009, 10:25 AM   #8
Rusty63
Flying near Stock is Best . Ive had my v4 two/half years . Only mods is Harder , blades . Esky cnc innershaft . Ive glued swashplate once . I do Fly Heli very hard . But as i said if you know/ think you are about to crash . Let throttle go . No / or little damage . More metal bits means Damage looking for next weak point . Its your money as mn wizard said wont make Heli Fly any better
ps.. With sloppy Blade holders are you sure its the Bladeholders . Could be the hub sets that hold them .
