Old 09-24-2009, 03:28 PM   #1
B400flyer
Exclamation Blade 400 a123 cells
I would like to run my blade 400 ok a123 batterys but first want to know if anyone has tried it yet?
I'm thinking allready that I'll have to cut/mod the frame for it to work?
B400flyer is offline        Reply With Quote
Old 09-25-2009, 08:21 AM   #2
meatbob
I thought about it, but decided against it because I would need to hack up the main frame
or run a split pack. 4S would be a very heavy heli. 3S would be okay, provided that you run a motor over 4000 kV, like the Scorpion 2221-6 or the E-flite 440H, and gear it appropriately. Also, you'd need to set your LVC much lower so that you can handle the lower voltages. This rules out the stock ESC, as the LVC on that is too high.
A123 cells are rather large, so you will need to get creative when mounting them. I have not tried it, but the promise of fast recharges is tempting. Since the Hyperion G3s came out, A123s lost some of their luster.
Logo 500 SK720, 4025-890, CC ICE 100
T-Rex 600 ESP w/3G - 12S, 4025-630, CC ICE 80HV
Blade 400 w/ HS5065MG, CopterX FBL, ICE Lite 50
eRaptor Conversion, 12S, 4035-500, JR 8700g, 3xDS610s
meatbob is offline        Reply With Quote
Old 09-25-2009, 02:35 PM   #3
B400flyer
Question motor size
well right now I'm running a scorpion 90amp esc with a Scorpion 2221-12 motor(2500kv?)
This would be to weak on 3 cell right? So should I use 4 cell
I also hacked up my frame a little and now I should be able to get 3-4 cell a123 bats in there pretty good.
Old 09-25-2009, 04:08 PM   #4
Starcraft-IX
a 90amp ESC??? Wow
With the lower voltage of the A123, you would definately want to run 4S, but it will be nose heavy unless you mount the battery differently.
MSR; MCP x, Nano CP X
Starcraft-IX is offline        Reply With Quote
Old 09-25-2009, 04:24 PM   #5
meatbob
4S is going to be heavy, especially with a 2500 kV motor. If you split the pack to two duals, and mount them on either side of the frame, you might be okay. However, I'd get a higher kV motor.
Old 09-25-2009, 05:08 PM   #6
B400flyer
Ok let's say I go with 4 cell with my current motor what pinion should I use? Right now I'm useing a 11 tooth and it's about 2000 rpm?
Old 09-25-2009, 05:56 PM   #7
meatbob
Using the readyheli headspeed calculator:
140 tooth main, 11T pinion, 2500 kV, 20C LiPo
3S LiPo - Avg Headspeed 100% Throttle = 1957 RPM
4S A123 - Same Pinion, Avg Headspeed, 100% Throttle = 2593 RPM
Since you are running a 11T on a lower kV motor (higher torque, btw), you'll probably be okay on battery life, but I really don't know.
Old 09-25-2009, 09:53 PM   #8
ingrahal
Do some searches on it. I found quite a bit of info some time ago but didn't save any of the info. Sorry. There were a couple of guys doing it though.
B400, DS285MG x3, DS3400G/GY401, CC ICE Lite 50, HK2221-8, Align 335mm Woodies, CNC Tail hub/grips, DX6i Tx
Blade mCX,Blade mSR
Flying Helis since April 09 Have mastered FFF ckts and nose in landings. Starting on mild aerobatics.
ingrahal is offline        Reply With Quote
Old 10-02-2009, 03:22 PM   #9
Tode
I run 3s1p a123, 40amp esc, turnigy 3700kv motor rewound 5t (same as factory but more copper),13 tooth pinion. Dont know my exact flight time max timer set at 5 min never notice drop during flight. Can fly full throttle curcuits for all five min or soft 3d (pilot cant do the hard stuff yet) zip charge at 10-12 amps can fly almost non stop with 2 packs.
Tode is offline        Reply With Quote
Old 10-02-2009, 04:09 PM   #10
everydayflyer
My son uses 4S 1100 A123s with stock motor and pinion, CC Phenix 25 ESC ,fixed governor mode 2550 HS , CF baldes,4 min. flights FFF and is learning 3D.
We data logged a flight yesterday, hard punch outs, kinda tick tocks, FFF, flips,flips to inverted and punch outs. .
Charles
everydayflyer is offline        Reply With Quote
Old 10-02-2009, 04:55 PM   #11
B400flyer
Question size difference
I'd like to use the 2300mah a123 cells but is there a big difference in size from the 1100?
Old 10-02-2009, 05:11 PM   #12
Starcraft-IX
yes, significant size difference. Just over twice as big
Old 10-02-2009, 06:00 PM   #13
everydayflyer
Understood but the 1100s are so simple and weigh less than a 3S 2200 LiPoly. Charge at 5A in less than 15 minutes, last 500 plus cycles, no special care required.
Charles
Old 10-02-2009, 06:34 PM   #14
meatbob
The 1100s will sag quite a bit under load. You averaged 11V under load, which is interesting for 4S. Thanks for the data! I did not see the crash in voltage towards the end of the pack, which suggests that you were flying conservatively at the end. That's been my fear with A123 is the fast crash at the end of the pack.
How many mAh went in at the recharge? Also, it would be interesting to see a 2221-6 with this setup. I suspect the voltage sag would be more remarkable.
Old 10-02-2009, 06:56 PM   #15
everydayflyer
That flight was only 3 min.My son normaley flys 4 min. but there is no voltage drop till the cells are empty. In a 4 min. flight he uses 800 to 850 mAh. Set and use a timer. Capacity used is in the legend on left . That flight 646 mAh used. Last minute was FFF and Blade 4oo just does not pull that much then.
Best source fro the 1100 cells is from DeWalt 18 V packs from E Bay.
This is the one and has 12 cells in it.
http://www.rcgroups.com/forums/showp...92&postcount=1
Old 10-02-2009, 10:17 PM   #16
xspare
Wow, do you like 2000 RPM? Does the tail hold? Any vids?
I ask about the tail because I accidentally ended up running 2150 RPM last month and the arse end of the heli was drifting all over the place, back up to 2600 RPM and the tail is locked in.
xspare is offline        Reply With Quote
Old 10-05-2009, 09:47 PM   #17
B400flyer
I don't really like 2000 rpm mostly because the tail does not hold that great but at least the battery life is good (7-8 minute flights)
Also I do have some vids on you tube just search my name (B400flyer)
Old 10-06-2009, 12:09 AM   #18
Epoweredrc
Here is a video of mine on the 4 cell 1100mah packs my father posted about. I am doing full flying, loops,rolls, stalls,figere 8's and what i call mild 3D flips, sort of tick tocs, flip inverted with hard punch out while doing peros. I am quite happy with the set up sure I could fly a 3 cell lipo and get 6-7 minutes but why, 4 minutes is plenty and with two packs i can fly back to back ( it takes a few mins walk to and from flight line, and take canopy off and on. I get wore out fly back to back as in no resting plus i take turns with my father when I fly with him.
I have 150 cycles and 110 real flights with mild 3D
last video I posted.. check out my others on youtube.
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is offline        Reply With Quote
Old 10-06-2009, 02:38 PM   #19
B400flyer
Thanks for the great info to all who have posted, I now have it down to 4 cell a123 1100mah. So I then was looking for places to buy the cell and I stumbled upon Hobby King and they have the 1100mah a123 cell for around $7-8 per cell. Does this sound decent? Also for those of you that are running a123 cells did you buy it premade or was I custom?
And lastly can everyone post there pics of there a123 blade 400?
Thanks so much
Old 10-06-2009, 09:13 PM   #20
Epoweredrc
Thanks so much
No problem, here is my B400 only thing I had to do was move the gromlets on the canopy back just a little ( my canopy is updated with magnets hate the gromlets)
but not issue. It blances just perfect. My father (Everydayflyer) builds all mine. there lots of threads on building your own packs.
Tags
b400 a-123
