Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > King II/III/IV and CP 2/3
King II/III/IV and CP 2/3 E-Sky King 2, 3, 4 plus CP 2 & 3
Old 09-26-2009, 06:22 AM   #1
KeithT
Default Set up help
Ok - I have got the K3 airborne at last - into a hover at least.
I noticed it still tends to want to rotate anti-clockwise but does so in sort of 'jerky' movements. Not wagging bac and forth, just a staged and gentle rotation.
Now I can control and reverse this, as my HBFP needs constant tail input, but I guess it should really hold very steady.
It has a BuzzFly HH gyro and I am using the BuzzFly 8Ch Tx/Rx with the HH gain set to 70%.
My question is - is that something I should keep trying to minimise by moving the rudder servo minute amounts, or is it best to trim it out? If the answer is trim, would that be sub trim or main trim?
Thanks for any advice
Raptor 50 TitanSE - AR7200BX + RJX head
Raptor 550E with a flybar!!
Align 500 pro with Speed fuselage
mCPX V2
KeithT is offline        Reply With Quote
Old 09-26-2009, 09:45 AM   #2
leonmike
I always use the sub trim for my helis instead of the main trim...
leonmike is offline        Reply With Quote
Old 09-27-2009, 06:33 PM   #3
Magenta
For a gyro in HH mode, trim (sub or otherwise) should not be used to attempt to correct a problem.
If the gyro doesn't hold, then the gyro isn't setup correctly, the mechanics (including tail rotor speed) aren't setup correctly, the radio isn't setup correctly, or the gyro is a POS
One more heli won't hurt anything
Magenta is offline        Reply With Quote
Old 09-28-2009, 05:41 AM   #4
Dusty1000
Did you set it up in rate mode first?
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
Old 09-28-2009, 05:29 PM   #5
KeithT
Hi Dusty - yes I did - and re-set it again today.....
Need to hover test tomorrow if it's not too windy.
I'll post back when I get a chance.
Thanks for the input
Cheers
mCPX V2
