Old 08-16-2006, 07:25 AM   #1
AV8TOR
Default Metal Head Stopper
Does anyone have the Metal Head Stopper (H60005) mounted on their 600? What is the diameter of the button?
AV8TOR is offline        Reply With Quote
Old 08-16-2006, 07:40 AM   #2
Danal Estes
I've seen them. It is just a tiny bit bigger than the "T" fitting in the head is across the narrow dimension.
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
Old 08-16-2006, 09:26 AM   #3
tcast305
Default Re: Metal Head Stopper
I have it mounted and it is really needed, since is a PITA without it. The dia of the head stopper is 36mm.
Thanks.
tcast305 is offline        Reply With Quote
Old 08-16-2006, 10:57 AM   #4
AV8TOR
Thanks a bunch
Old 08-16-2006, 03:58 PM   #5
Danal Estes
Originally Posted by tcast305
...it is really needed, since is a PITA without it.
As someone who DOESN'T have one mounted, I thoroughly second that PITA comment!!
Old 08-16-2006, 05:34 PM   #6
clayk1
What does the headstopper do? Just what it says, give you a place to grab to slow down the head when you land? I put one on because ti looked cool
Clay
clayk1 is offline        Reply With Quote
Old 08-16-2006, 05:49 PM   #7
shannimal
I use it to land inverted...DOH!!!
Fly it, Dare it, Damage it!!
shannimal is offline        Reply With Quote
Old 08-16-2006, 11:42 PM   #8
Skiddz
It gives you a place to put your shotglass when you're wrenching on the heli.
-Kevin
Skiddz is online now        Reply With Quote
Old 08-17-2006, 01:40 AM   #9
zx12rRed
i mean really if your in that much of a hurry to stop the blades after a flight well then you need to take some slow down drugs, it akes what how many seconds for the 600 blades to stop spinning, by the time you get to it from your pilot area they are normally just about stopped
Like the other guy said i go mine because it just looks good, i rarely use it to stop the head :wink:
zx12rRed is offline        Reply With Quote
Old 08-17-2006, 01:44 AM   #10
Symon
Yup, when you're all switched off you put the palm of your hand on it to slow the rotors down. (after you've switched off!! hehe)
PMSL
I hope you guys are going to join
Symon is offline        Reply With Quote
Old 08-24-2006, 10:58 AM   #11
reades
I added it. I think it gives a nice finished look.
reades is offline        Reply With Quote
