| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
My second hand 700 has +-14 degrees collection and 12 degrees of cyclic.
The cyclic values seem awfully high. I've read I'll get binding in the corners with over 7-8 degrees cyclic. I'm thinking +-12 and 7 would be good. What are you guys using? thx |
+-12 and 7 cyclic sounds about right, run any more collective and you need to be very good at collective management. I think I may be running 8 degrees cyclic but using the 10CG I have the swash ring feature active so no binding in the corners.
One factor that will affect both is the blades you are using, both brand and length.
Steve H Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG |
this may be obvious, but whats the best way to get an accurate reading for cyclic pitch?
T Rex 700N - OS91HZ-PS, 8717's, G7703D/8900G, Radix MB's, Align 2n'1, Align gov, Rotor Rage 30%. <-- LOVE it! T Rex 500ESP - Radix MB's, G7703D/3500G, Thunder Power 2700mah 6 cell's. Spektrum DX7 |
Not sure if this is the perferred way, but I measure it using my pitch guage on the main blades with the blades in line with the tail boom. I move the right stick to the max throws for ali and ele then measure.
Me too bought a second hand 700N and i readjusted the head as per Finnless headsetup and used the align servo weels with no subtrim (great thing those servos wheels) but i am only able to get barely 12° of pitch. It is surely enough for my style of flighing but i am wondering how every body else gets 14°. My Pitch compensator is allready hitting the headblock with 56% Pitch mix on my DX7. Anything i could have done wrong??
the servo wheels are 90° the swash is level at midstick the Pitch is 0°. i could get more negative Pitch but at positiv i am at the limit. And you can not lower the swash with this A-Arm design. Any insights? Would a Picture of my head may be helpfull?? i am using a Walkera Pitch gauge. Did well so far and my NHP 710 Blades are the biggest blades this Gauge can swallow Picture is coming!! Sorry for the bad quality of the Pics may be tomorrow when i go fly i get some better with propper illumination!
Helis:; Kasama Srimok ECO - V-Bar; Kasama Faifa LRH V-Bar!!! Radio: MX-20 Hott |
#6 |
Are your washout arms in line(level) with eachother at centre stick?
and your blades 0 degrees at centre stick? |
#7 |
Yes. I settled for +-12 degrees for collective and 7 degrees cyclic and it feels good. I may end up going for more cyclic once I get things settled.
#8 |
All Arms are in line as per the setup Vids from Finnless. Thanx by the way Bob for all the effort you have made over the years. And you enspired more and more people to record vids of there builds to support the comunity!!
#9 |
7 on cyclic kinda too slow ... i used to have 8 on cyclic and now its 10-11 on cyclic.. its a big different to do aileron tick tock on 7 and 10 cyclic
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
Sounds like you need to shorten your swash plate links to bring down the swash. I had to actually file down the A arm ball link to get the swash lower, me and another guy did the same thing and have been flying it pretty hard all year. I can get 14 and 14 if I wanted too, but I opt at 12 and 12.
~ If it ain't broke....Let me fly it ~ |
#11 | |
