| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I am in the process of building my 600NP and when I went to install the servo bellcranks I noticed that the shaft WILL NOT go through the bearings or the center bell crank!! It seems the shaft diameter is too big. has anyone else had this problem? I tried putting the shaft in a drill and sanding it down but no luck still wont go. Other than getting a new shaft and hoping its the right size does anyone have a recommendation? Thanks.
Problem solved! guess i just got a bad one went and picked up new ones and they fit fine.
Very odd. Thanks for the info.
T-REX 600 SNP: Stock Blades, OS 55HZ Hyper, Hyper Pipe, 9254 Cyclic , BLS251 w/ Spartan 760, Align 2-1, MultiGov w/Spektrum RPM backplate sensor |
