| Belt CP E-Sky Belt CP |
Guys! What I need to change is the shaft that runs off the main gear that turns the belt that turns the tail rotor. Its the front one that connects to the bottom gear thats under the main gear that the motor turns. Any easy ways to do it other than tearing down the whole heli? Thanks Ed
#2 | |
TDR - Logo 600SE + 500SE + 400 - Furion 450 6S mini-V - 300X - 2 x mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner FAI world record longest electric RC heli flight: 1h 46m 22s |
For reference ED its called the tail auto rotation gear, saying there is a shaft and a pulley that turns the tail is discribing the tail drive gear and pully that sits behind the main gears, might of been easier to just ask how to take the main gear out as its one assembly.
We will always try to help you or any one else with a problem but we can only work with what we are given understand that lanuage can be an issue with some but just try to be as clear as possible in the explanations of problems and it will save you frustration
Alex To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Stop by say hi :-) 500 ESP: Ely Q Comp: "Kasama'd Trex 600N: |
