Old 08-20-2006, 08:22 AM   #1
FBaity
Default Pro2K Parts
I have a 1999 Pro2K and looking for head axle # 0848-1. Rick's has informed that Min Air no longer has these axles available. Anyone have any laying around I could buy?
Frank Baity
AMA 38026
FBaity is offline        Reply With Quote
Old 08-20-2006, 08:51 AM   #2
DavidH
http://www.miniatureaircraftusa.com/...xt=0848-1&pg=1
As far as I know. MA still has those axles. That is the axle that fits the all metal 0848 rotor head. That head was on the SE also, so there is still a good number SE's out in the heli world flying. The only difference between the 120-5 Extreme axle and the 0848-1 axle. 0848-1 is about 4 mm longer than 120-5.
I have an 0848-1 new in package.
David
DavidH is offline        Reply With Quote
Old 08-20-2006, 09:26 AM   #3
FBaity
David,
I talked with Ron several times trying to get a 0848-1 axle with no luck. Ron sent me a 120-5 Extreme unit which I don't see how it will work with the Pro metal blade grips that attach to the aluminum spacer between the radial bearings. I would be glad to take that 0848-1 antique off you hands should you want to part with it.
Frank
Frank Baity
AMA 38026
Turbine Waiver RW-545 FW-14690
Align 450 SE V-1
MA XL-Pro 2K
Bergen Turbine X 2
Old 08-20-2006, 10:35 AM   #4
DavidH
http://www4.mailordercentral.com/hel...?number=114055
Heliproz has the axle. If you don't want to get it from them. I will sell you the one I have.
MTA hobbies also shows they have 08848-1
120-5 will not work with the metal blade grips. It is too short.
David
