Hey all has ayone tried installing the torque tube from the new pro kit on an older SE kit? I want to do it but I'm afraid the mod will change the length of the boom
I've heard of it being done on the v2 450's. I don't know of the standard v1. Boom length? would it matter?
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
The SE V3 tail boom mount is drilled different than the Pro's bolt pattern also, I think the gears and boom are the same possibly. I saw different mounts listed lately.
How much past 200 mph do I need to go you ask? |
The pro TT is a bit different. Why not go for the V3 TT upgrade. It's made for the 450 S/GF/SE/SEV2. Do not confuse the Pro with V3. The term V3 is used for the latest option parts for the V2.
http://www.align.com.tw/shop/product...oducts_id=2726
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Correct, the boom blocks are all different between the V3 TT upgrade, Sport, and Pro. Aside from that, the only difference between the parts of the V3 TT upgrade and the Pro, is the drive gear.
Warp 360 Spartan Vortex VX1 |
#6 | |
#7 |
nah, technically its called the v3 tt upgrade. i know for a fact that that upgrade kit will fit the se as well as the v2 and the sport. also, the booms are the same length. the difference between the pro and the v3 tt is the boom block, counter gear/input shaft and color of the tail case that comes with the kit. when you're looking for parts for this, all of the pro TT parts and booms are the same, but you just have to make sure you get the V3 counter gear/input shaft guy. also, when doing this kit, you should have your elevator(rear) servo on the outside of the frame and sometimes shave the servo horn, otherwise the horn will contact the pyramid gear and cause binding.
on the whole, it's an awesome upgrade, you'll get nearly a full minute more of flight time out of it, as well as consistent sharper tail control. i love mine.
Thank god i have snowboarding to keep me occupied when its too cold to fly! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Do you have to use the boom in the kit or can you use a carbon boom with the upgrade?
Trex 450Sport, AH64D Longbow Apache To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA 470413 NMPRA 26Q |
#9 | |
