| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
There are so many regulators on the market, its confusing me on what is needed. I'm building a Rappy SE with Align 620s. What AMP draw should it be able to handle? I like the idea of having on-board glow, like the Align 2n1, but not required. Any input, or recomendations?
Thanks ahead Whiskey |
Three Align servos should not draw more than 5A, add the gyro and tail servo and you should never see more than 7A. Remember that stock servo wires and the bus at the RX will only take 5A continuous, so make sure the feed wires from the regulator is a little thicker than stock servo wires. If it has two outputs it will even be better, one output for the cyclic servos and RX, with the second one for the gyro and tailservo.
A 10A regulator should be enough, just take note that ALL regulators have diminishing output capabilities with an increase in input volts, even the switching type, ie CC's new switching regulator claims 20A output, but only if the input is 8V or less, at 20V input they only rate it at 5A.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC Hyperion 1420, Mega Power Gemini Chargers! JR XG11 Old hand at Planks To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#3 | |
16V = 15A 24V = 13A 32V = 11A 40V = 9A 48V = 8A
T-Rex 500 |
I have a 600n and just built a Hirobo SDX. I use the Align 2 in 1 on both. Never had any problems. The 600n runs 5 full size digital servos, an hs55 for the CarbSmart, a 611 gyro and a GV-1 governor. The Hirobo will be getting a CY ATG after break-in and probably a CarbSmart. The Align 2 in 1 will work just fine. Alan
Blade CX/2, Axe CP, T-Rex 450 SA(SE V2 now) , T-Rex 600nitro Pro, Blade mCX, T-Rex 500 GF, T-Rex 450 SE night rig with ZeroGear and FlexPro lighting, Walkera 4G3, scale 450 Hughes 500D, Hirobo SDX HPM, Blade mSR, DX7 |
