| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I'm planning to buy the NEU 1515H/2.5 DF motor for my 600ESP.
My first concern is if it is a direct fit without any frame modification or cut (considering that it is a 49mm width motor when I had some difficulties installing the 48mm Hacker A40 10L on it). Would it fit? ![]() Can the 1700Kv NEU 1515H/2.5 DF reach 2000 RPM at 80% throttle with an 11T pinion (will be using governor mode with my CC ICE 100)? According to my calculations, it should reach 2K RPM at 80% with the 12T but not sure what is more efficient in a battery consumption perspective. Finally, does the motor wires fit in a 6mm bullet connector? My flying style in mild 3D. Any answer is welcome, Thanks, Ricci. Last edited by Ricci; 10-21-2009 at 03:42 PM.. |
I use an 11T pinion w/ my HV110.
I run it governed at 2025rpm (pretty close to the max using the standard gov mode) and that's the perfect amount of power for me (for now). The motor fits perfectly in the stock frames w/ no modifications. I'm pretty sure I'm using 6mm bullets (just like what's on the Align motor). Enjoy...it's a great motor for 6S.
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 600ESP V-Bar, 700E 3G T-Rex: 550 DFC |
OK Thanks for the feedback.
I have now installed my new NEU 1515H 2.5 DF motor and begin to test it. When connected to the main gear (with the correct mesh and backlash, not too tight) and pushing by hand the rotor, it apparently has more resistance than the stock Align 650L and produce more noise on spool up. Is this normal (maybe because it has only 4 poles)? Thanks, Ricardo. |
Are you using the stock ESC? If so, then yes. If you're using the stock ESC, there's a grinding sound on spool up. That's normal. I use a CC HV110 and it's smooth...just a different kind of soft start. Don't be worried about the noise though. It's normal.
#6 | |
As I said before it is harder to push the rotor with the hand because there is more friction and when shutting down the motor after spool up, it stops much quicker. Curious thing is that the gear mesh is the same I use with other motors, which looks OK (11T modulus 0.7). Note that I had to lower 5mm the motor in order to have the correct vertical contact between the pinion and the main gear (using 4 spacers on each screw). Ricci. Last edited by Ricci; 10-30-2009 at 05:16 AM.. |
#7 |
I am begining to believe that the 11T pinion may generate more friction that 14T or 15T pinion even if it is the same modulus.
Tomorrow I will do some more pinion test and let you guys know. Ricci. |
#8 |
#9 |
Thanks Dieselracer, I have already seen your impressive video and I know how powerful is this motor.
Did you have to lower 5mm the motor so the pinion would be at the correct high on the main gear? Do you fill a bit more resistance of this motor when pushing the rotor by hand and everything off? Thanks, Ricci. |
#10 | |
I am not sure what you mean by the resistance. When spinning the main gear, it does feel different then the stock motor. |
#11 | |
The pinion mesh is OK, but maybe there is a difference because it only has 11T. Thanks, Ricardo. |
#12 |
I agree, it's a little tougher to spin it by hand, but not significantly. I think part of it is the smaller pinion and part of it is the 4 pole. One thing you should keep an eye out for is your main gear wearing. After flying 50 or so flights on mine, I'm starting to see uneven wear on the gear. I also stripped a main gear when pushing it to hard during tick-tocks. I have since added the 3rd bearing block and haven't stripped a gear since.
I actually caught it on video:
#13 | |
Does this motor get very hot (even with the fan cooling system)? ![]() My main concern about the extra-resistance of the motor is that is may generate more heat... Also in my first spool up test (in my home office) it does get quite warm after 30 seconds... Ricci. |
#14 |
Hot? Absolutely NOT....barely gets warm! I have lots of Eagle Tree graphs in one of my albums that shows the temp.
#15 |
Well, mine is getting up to 150 °F after only 90 seconds, so I should be using bad values on my CC ICE 100.
Can you please indicate me your PWM rate, Motor Timing and Motor Start Power values? I'm quite frustrated because this ESC is cutting off the motor after some 90 seconds. My first test values were: PWM rate = 12 KHz Motor Timing = 1 Motor Start Power = 39 (Low) I raised my Motor Timing to Normal (5) but cannot test it again until Tomorrow. Thanks in advance, Ricci. |
#16 |
If you spool it up indoors with no blades the motor will run much hotter.Actually any motor for the matter. even though it does have a fan, It gets most of its cooling from the outside air. Once you run it outside in the air, it wont run hot. When i balance my tail blades on the heli with not head on it. The main motor does feel hot. But it never gets that hot in flight.
#17 | |
Can anybody confirm me the appropiate frecuency (should be 12 Khz) and timing values for the NEU 1515H / 2.5 DF? Thanks, Ricci. |
#18 |
I left frequency default. And for timming Steve Neu recommends low.
#19 | |
My first real test flight with this motor in the morning is really promising, I can feel the power even if I just did some hover (no much room to fly) . ![]() Howerer, the electricity consumption is also a bit higher, so maybe the lower timing will improve this aspect a bit. Cheers, Ricci. |
#20 |
Is it necessary to grease the NEU motor bearings periodically?
With oil or grease? Thanks, Ricci. |
