Old 10-22-2009, 07:22 AM   #1
mapas
Default How long do servos last ?
Hi,
I have 300 flights with my 5245MG. Very few crashes (i replaced the servo plastic box a couple of times).
They are working perfectly right now.
What is the life expectancy of the servo motor ?
Should I replace them (just in case) ?
Did you ever have a servo failure (that was not caused by a crash)? After how many flights ?
mapas is offline        Reply With Quote
Old 10-22-2009, 08:18 AM   #2
whisperdancer
Your tail servo has already worked a 1000x times more than your cyclic servos...
MSH Prtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 10-22-2009, 09:48 AM   #3
jlharv
I am right there with you. Right around 300 flights, 3 crashes and they are still going strong. If I don't see any signs of failure or getting weak, I will run them until they die.
Now that it is getting colder here, I will probably break down the head, put new grease in the thrust bearings and re-setup the head, make sure all the pitches are correct and level. Check bearings etc... If the servos aren't moving the same as when they were new, it should show up there.
John
nCPX , 130x, DJI f450 5.8 GHZ FPV, T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is offline        Reply With Quote
