| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I installed the quick uk tail assembly today. Should I remove the blade grips or are they okay loctited from the factory?
V-BAR Guru
All mine has been good, but you can always check by just putting some force on the screw.
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Mine came loctited but I know because I always remove every part.
Be safe and remove them to check. Sometimes they also apply to much loctite.
6HV, BLS451, Quark+MKS BLS990, Jive 80HV+Compass 540KV 3D+, Savox 1258TG, Spartan DS760+MKS BLS990, OS55HZ+Funtech B320 Rave ENV, Savox 1267MG@6.6V, BeastX+MKS BLS990, YS91SR+Hatori SB19 All controlled by a DX8 |
i just bought some from Ready Heli, but for now i have some washers under the tail grip bolts , it seems to take all the play out , now it's nice and solid
The play is there for a reason, it goes away as soon as you spool up, I really suggest you remove the washers
SPEkTRUM DX8 TREX600NSP VStabi V5.3 / 55HZ TREX700N DFC/3Gx/ 105 HZ-R |
#6 |
I dissagre.. trust bearing are no reason for play, yes they will be stiffer when spinning but thats not always true, bought Align 600/700 tail gripp and they had the worst play ever, even worse than plastic stock!!
have ordered some now bearings and shims to c if it possible to fix or just to return!
Anders Lundström T-Rex 700N Pro, HZ-PS .91, Outrage, AR7100R, VBar, BLS 451*3, BLS 251. T-Rex 600 ESP, Scorpion 4035-560, Jive 80HV, VBar, Align 620*3, JR 8900. T-Rex 500 ESP, Stock, Mini-VBar. C-ARF Yak55 SP 2,6m, 3w 106 |
#7 |
Here is a illustration of what i did.
#8 |
looks ok if you dont ever tighten it :-)
Got my bearings but it didnt do anything to the horrible play for the align alu grip, same crappy play.. but you can add another bearing under the thrust bearing and use a longer screw, problem is that there isnt enough axis on the spindel to put the bearing on, well fix a 4mm long and 5mm wide tube and it will be fine, use lots of loctite, no play :-) edit: on the other hand get some others, more safe :-)
Anders Lundström T-Rex 700N Pro, HZ-PS .91, Outrage, AR7100R, VBar, BLS 451*3, BLS 251. T-Rex 600 ESP, Scorpion 4035-560, Jive 80HV, VBar, Align 620*3, JR 8900. T-Rex 500 ESP, Stock, Mini-VBar. C-ARF Yak55 SP 2,6m, 3w 106 Last edited by Ludde; 10-30-2009 at 07:22 AM.. |
#9 |
Not sure if i mentioned it, but i am still using the plastic stock grips.
I think i will wait a while to see if i get any play in the blades , if all holds good after about 3 or 4 more flights then i will wait till i hit the dirt ![]() |
#10 |
Everything is still tight as a lug-nut on a 55 chevy
#11 |
The stock plastic grips and tail assembly seems better and tighter than the Align metal ones. The tolerances seem better IMO. I did however replace my 700 tail grips with Quick UK ones, and liked the result so much that i picked up a set for my 600 as well. They're more "bling" than improvement on function, but they are very smooth, and allowed me to add a few points of gain without wag.
700N - Microbeast MSH Protos - Microbeast To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 |
post deleted wrong thread
#13 |
Please read my last post on this thread,
http://www.helifreak.com/showthread.php?t=184793 After I took the Align metal tail grips apart, greased them and put back together, they had no play at all, they were nice and smooth like butter with no play .
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
