Old 10-30-2009, 03:25 PM   #1
ToMeToYou
Default Help with head setup please
Okay here goes, I can get +/- 13 with this. All the links are set to the manual give or take 1mm. The washout does not line up at 50% throttle and nor does the top part ( dont know what its called ). Is there any problem with this?...Probablly is :o
Low stick:
Mid stick:
High stick:
Regards,
Jon.
Trex 600N Pro / Align 2 in 1 / DS610 cyclic / DS610 throttle / CY ATG / GY401 & S9254 with step down
Trex 500 CF / Stock motor and esc / 15T pinion/ GY401 & S9254/ Revolectrix 5s 4200mah / AR7000 /
Trex 250/ DS410 Cyclic/ Align GP760 S9257/Microheli tail / I Spektrum DX7 - Cellpro 10s I
ToMeToYou is offline        Reply With Quote
Old 10-30-2009, 03:58 PM   #2
EO19
Shorten the short links that go to the blade grips until the arms are level. The links will be with a few mm's of touching.
Shorten the link coming from the flybar cage until the arms are level.
EO19 is offline        Reply With Quote
Old 10-30-2009, 04:04 PM   #3
ToMeToYou
Enough though the manual says different?
Old 10-30-2009, 04:44 PM   #4
Sonic_BOOMER_SOONER
Yes, consider the manual lengths a starting point.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se
Sonic_BOOMER_SOONER is offline        Reply With Quote
Old 10-30-2009, 05:49 PM   #5
Altec
Hi tometoyou...I saw something that didn't look right in your pics. Mid stick last picture...
Make sure your TX stick is at 50% (mid stick). If it is then this isn't right. I'm going by the arrows that I numbered...1 and 2 should be at a 90 degree angle. 4 and 1 should line up perfectly, see how the servo horn is off to the right a bit?, it has to line up, if they don't then you have to keep moving the servo horn around until they do. Once you fix that then 3 and 2 should line up as well.
Hope that hopes and you follow it. Good luck.
Altec is offline        Reply With Quote
Old 10-30-2009, 06:48 PM   #6
ToMeToYou
Cheers, I'll change that tomorrow. Im going thought all the head again and going to reset all my settings and start again on this second hand model. Will post pics when im done to make sure ive done it right and you can take a look.
Regards,
Jon.
Old 10-30-2009, 07:17 PM   #7
helical
Not sure how experienced of a pilot you are so I'll assume, and maybe mistakenly, that you're on the newer side...I just want to make sure that you know this...
With +/-13 collective the swash WILL bind on the washout pins on the high side and the bearing block on the low side IF enough collective and cyclic are inputed at the same time. If you're experienced enough and can manage never to do this in flight then you probably already know this. If not you may want to dial down the collective a bit and then check for binding at full collective and cyclic on both the top and bottom.
If this is already obvious to you then please ignore me.
helical is offline        Reply With Quote
Old 10-30-2009, 07:49 PM   #8
Altec
tometoyou, heres some pics of mine of what it is supose to look like when you have you TX at mid stick....
Old 10-31-2009, 06:48 PM   #9
ToMeToYou
Thanks for the info and pictures, tonight i set up all the links on both the servos and the head, all i have left is the links at the very top which change the pitch of the blades. I will be finishing this off tomorrow night. I managed to get all servos 90 degrees and the swash level to the eye, only needing a few clicks on aileron and elevator. Keep watch on this thread as i will probably be posting some problems tomorrow night knowing my luck. ( afternoon for you ).
Thats a nice 600N LE you have there Altec, got any more pictures of her? Was thinking of getting one if i get extra hours over the christmas period at work - Being a limited edition will there be spare parts of the titanium parts if they break in a crash?
Regards,
Jon.
Old 10-31-2009, 08:48 PM   #10
Altec
Sure, I just uploaded some more...
http://www.helifreak.com/album.php?albumid=3458
Old 11-01-2009, 07:20 AM   #11
brunsflyer
used bird?
i setup my head with no links on first!
1. center the servo horn with TX @ 50. used trim or mechanical.
2. measure the distance from horn center to center of arms. different servo will change this measurement from 1mm to 2mm or less. the math cannot be wrong if both links are at this measurement! double check the arms are now at 90 too.
3. the new a-arm will help you to just check the back two links to level the swatch.
4. now i just check everything from bottom to top! make everything 90 to blade grips.
im a math guys so if you are right from the start you can get everything perfect to the top of the head.
hope this helps.
T-rex 600 N Pro
GY611 with BLS251
GV-1; BLS451
OS 50 HYPER, Hatori Bob Watts Pipe
TT 600 Carbon Blades
brunsflyer is offline        Reply With Quote
Old 11-01-2009, 05:36 PM   #12
ToMeToYou
Finished Ready for test flight when my KBDD paddles and tail blades arrive. Been waiting 7 working days now but stupid Royal Mail are on stike over here in the UK.
I have a few clicks here and there on the AIL and ELE and the swash mix is:
AIL: 45
ELE: 45
PIT: 55
This provides +/- 12 degrees pitch, give or take.
The arms are not perfect 90 degrees but more or less. Here are some pictures of the new setup at med stick, but as i said still needs test flight.
Med stick:
Looking good?
Old 11-01-2009, 05:59 PM   #13
Altec
Looks allot better on the aileron arms and servo wheels. There looks to be one more adjustment you should make. The Elevator servo horn may need to be adjusted, it looks high from the picture. The red arrow I added should line up with the red line that you made on your orginal pic.
Old 11-02-2009, 05:07 PM   #14
tqcookie
You might want to look at the rudder linkage also. It appears as the servo wheel rotates it is contacting the linkage and causing it to bend a little.
TEAM LYNX HELI
Hang down, flip it, and reverse it !
tqcookie is offline        Reply With Quote
Old 11-02-2009, 05:15 PM   #15
ToMeToYou
Tqcookie, thanks for that. The tail servo link is not bending or binding in any way, thats just the camera making it look like that. Ive just checked it to make sure and its fine, Bind/Bend free
Old 11-02-2009, 06:02 PM   #16
ToMeToYou
Altec, Thanks once again! To say the least...
I couldn't keep the digital caliper straight, and i know the aileron arms are not exactly perfectly 90 degrees nor is the elevator arm but what is perfect in this world?
Still waiting on my paddles and tail blades through the postal strike, rang Fast Lads and they said if they don't arrive by Wednesday afternoon i should ring them up and they will send me them out again. Now that's what i call service!
Thanks for all the help guys,
Jon.
Old 11-02-2009, 06:09 PM   #17
Altec
That looks pretty dam close Jon. Just remember to level your swash without your head on and the servos at mid stick (or at least as close as possible). I wouldn't "eye-ball" it...it's usually off by quite a bit. Like someone said earlier here, the measurements for the links in the manual are starting points. One turn will make a big difference weather or not you have to use trim.
Old 11-02-2009, 06:31 PM   #18
ToMeToYou
Im not going to mess with it now its all ready. Will test fly her in the garden once the post arrives...if the post arrives...then its time to give her a real maiden flight
Now to get some and order a 600 LE
Happy flying,
Jon
