Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 08-27-2006, 02:57 PM   #1
Rebuild
Default BCP needs longer main shaft, help!
Scale project is going to require longer main shaft on BCP. Anybody have an idea what I should get to fab new shaft. Can ya get drill rod the exact same O.D. as stock shaft or is the stock shaft some kind of a manufacturers morphed size to thwart would-be do-it-yourselfers?
Rebuild is offline        Reply With Quote
Old 08-28-2006, 11:01 PM   #2
zooland1
Century's main shaft for the HB CP2 is longer than the stock one and comes with a removeable main gear. You can even buy an autorotation gear for it. I got mine from Heli-direct.
zooland1 is offline        Reply With Quote
Old 08-29-2006, 08:51 AM   #3
Rebuild
Thanks zooland, but I need an extra inch or so!
"To fly is human, to hover is divine!"
Old 08-29-2006, 12:44 PM   #4
zooland1
Buy the main gear from the CP2, pull the 3mm shaft out of a cdrom and carefully drill your shear pin holes. Better yet, order the gear and let me know what distance you'll need and I'll send you one. The hardest part in that respect will be getting links long enough. You'll need some 2mm threaded rod and threaded links. Let me know if you decide on the auto gear or standard, I think they use a different shear pin and I'll need to know the dimension. I have the auto gear so if you decide on that one I can do that size from mine.
Old 08-29-2006, 09:28 PM   #5
Rebuild
Gotta love this place! Thanks zooland!
Old 08-31-2006, 12:18 AM   #6
zooland1
PM me with the actual length you need and I'll make it.
