Old 08-20-2010, 08:01 PM   #481
Anthony440
Here is a test flight with my shorter mount. Pretty good as far as vibs
Anthony440 is offline        Reply With Quote
Old 08-26-2010, 10:22 PM   #482
Slyster
Something new!
Fellow at my field bought a set of these. Talk about making it easy to video your flights! Same quality as the regular keychain cam that many of us have.
http://cgi.ebay.com/Mini-DV-DVR-Spy-...efaultDomain_0
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 08-28-2010, 03:10 PM   #483
Mentalic
Been following this thread for a while and I finally purchased one of the so called "#3" type keychain cameras since there supposed to better than most. Well I don't know yet since its raining non stop here!
Built what I hope to be a vibration proof mount because I flew another flyers keycain cameras a month ago and it was full of the waves with a solid mount.. Anyway I'm hoping this mount works well.
It mounts to the extra skid mounts on my Logo600se, its very rigid and has a weighted tray for the camera. Used 1/2oz of lead under the tray, zeal gell for anti vibe support.
I'll post back how it works, that is if it ever stops raining!
ID:	176713   Click image for larger version
ID:	176714   Click image for larger version
Wayne
Logo 600/ Logo 600se/ Logo 700
Mentalic is offline        Reply With Quote
Old 08-28-2010, 04:14 PM   #484
perfeet
Very cool. Please post the result asap
Regards perfeet
- Mikado Logo 600SE (Vbar 5.0 and 12S)
- Parkzone Habu (5S)
- ArtTech Wing Dragon Sportser
perfeet is offline        Reply With Quote
Old 09-05-2010, 09:36 PM   #485
Mentalic
Made a few tests and revised the mount to use two layers of zeal and 1oz of lead.
Tried different head rpm and found that lower was not better for my logo 600se. Take off is at 1600 rpm and flight was 1850 rpm. Video is at my local flying field and its still wet from all the rain...
Wayne
Old 10-04-2010, 09:06 AM   #486
Spork01
Wow. that is a fantastic mount you made. very smooth!
Has anyone tried out the HD version of the spy camera? this one http://cgi.ebay.com/Key-chain-Mini-D...item20b390be98
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is offline        Reply With Quote
Old 10-04-2010, 10:40 PM   #487
BBRFST
That's the smoothest I've seen yet with that camera
Atom 500 VBar (Takes a licking), MCPx 2s (Flying
), Atom 7HV-Bar (Flying LARGE!!)
BBRFST is offline        Reply With Quote
Old 10-04-2010, 10:43 PM   #488
Slyster
NOT true HD at all... I have one.. video up above somewhere.. truly not worthwhile.. since it only up-converts the resolution using built in software... but basically uses the same imaging chip.
You can increase your video size using the regular cam with your movie software. Sure it's bigger.. but at a cost of quality. Plus you then need a high speed memory card.. mine doesn't make the cut and has pauses in the video.
Pete Team Outrage.
Old 10-05-2010, 05:34 PM   #489
Mentalic
Thanks guys! Its working well enough for my needs.
After flying it a few more times I find I need to make a wedge to use when taking look down shots from altitude. Just going to use hardwood and Velcro.
Wayne
Old 10-05-2010, 05:52 PM   #490
Kozmyk
That permanent tilt you've got in your key-chain camera is quite easy to fix.
Once you get inside the video head is only held in place with a dab of hot glue.
It's very easy to line it up and reglue, either with a hot glue gun or a soldering iron.
I've got two of those cameras and I had to do it to one of them.
Koz
Some helis ... some planks
. Phoenix/Simstick
I've found a way to halt reckless heli spending ... Go Broke.
Kozmyk is offline        Reply With Quote
